JamPS Posted September 9, 2005 Posted September 9, 2005 DVBViewer won't receive any remote buttons, though winlirc icon displays green when I press a button. I can't set the button config in DVBViewer either. Once I got it working(did a reboot or something) and tried different DVBViewer versions... but not anymore. Quote
Guest Lars_MQ Posted September 9, 2005 Posted September 9, 2005 But you did activate winlirc in the DVBViewer options? And be carefull with firewalls. maybe they block winlirc locally (127.0.0.1). Winlirc transmits via tcp/ip, Quote
JamPS Posted September 10, 2005 Author Posted September 10, 2005 Ah, problem solved. Didn't know that winlirc uses tcp/ip... Quote
