pe3k Posted September 10, 2005 Posted September 10, 2005 Hello, I have discovered my picture is freezing every few seconds while watching a program and if I play recorded stream I get dropouts and squeaking noises.. I tried to reinstall and uninstall the program completely, but it doesn't work.. What should I do? I use Cyberlink video codec and Main concept audio codec.. Even if I change the video codec the problem persists.. Quote
Guest Oliver Posted September 10, 2005 Posted September 10, 2005 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
pe3k Posted September 10, 2005 Author Posted September 10, 2005 ok, here's some more info.. I haven't found the DVBViewer.log file.. hope this is enough setup.xml MPEGDecoder.txt Quote
pe3k Posted September 20, 2005 Author Posted September 20, 2005 hey ya'll the problem disapeared when I upgraded to version 3.2.2. that means no more dropouts or problems with turning the DVBViewer off. even though, be very careful when installing Nero stuff, I think that's when I've started to have problems with dropouts and picture freezing because of the nero codecs.. Quote
