bluepill Posted September 12, 2005 Posted September 12, 2005 Hi, I've just got my Twinhan VisionPlus 102G (DVB-S) and I'm wondering - will I be able to use with DVBViewer? I'm located in North America. Thanks in advance. Quote
hackbart Posted September 12, 2005 Posted September 12, 2005 Well according to the Twinhan specs it should run fine. Christian Quote
bluepill Posted September 12, 2005 Author Posted September 12, 2005 Thanks for the reply. North America uses mainly LNB's with Circular Polarity and LOF 11250 MHz... The question is: will it work without recalculating the TPs freq? Regards, Blue Quote
Derrick Posted September 12, 2005 Posted September 12, 2005 will it work without recalculating the TPs freq?..if you set the LOF accordingly Quote
