stax Posted September 17, 2005 Posted September 17, 2005 I wasn't much successful with my prior issues so I don't invest much time (reading the guidlines etc. takes some time) in doing a proper bug report because I'm afraid it might be a waste of time, sorry about that, maybe the report still might be useful. I got a osd msg box at startup (new version availabe) and one at shutdown (really want to exit) I cannot disable. I hope at least it won't effect the scheduler because then I'm not much concerned. I don't want to update because I never change a running system that is configured properly and does all what I need unless I know the system is fixed or much improved. Quote
Guest Lars_MQ Posted September 17, 2005 Posted September 17, 2005 Well the first one will be corrected in the next version, so it is shown only once. The second one is corrected in the current version. So either you live with it, or you update (which will make the first msgboxalso disappear ) Quote
stax Posted September 17, 2005 Author Posted September 17, 2005 Thanks! I'll update next version then. From where do you know about that? I didn't find a changlog stating it was fixed. Quote
stax Posted October 9, 2005 Author Posted October 9, 2005 I've updated to 3.2.4 but still get the osd msg box asking if I'm sure to exit. Quote
stax Posted December 28, 2005 Author Posted December 28, 2005 Hi, any chance to fix it? Besides [removed] it's the only thing not working here. Regards, stax Quote
Guest Lars_MQ Posted December 28, 2005 Posted December 28, 2005 First read the forum rules. [removed] is not to be discussed here and second, what problems do you have. The current version is 3.2.6 and the above mentioned stuff is fixed a long time ago... Quote
stax Posted December 28, 2005 Author Posted December 28, 2005 I have 3.2.5, when I disable Check for DVBViewer Update on startup, confirm the options dialog, restart, guess what happens? Quote
Guest Lars_MQ Posted December 28, 2005 Posted December 28, 2005 Oh yeah an old known bug, 3.2.6 fixes it work around: disable the option and change another option on the page, the apply should work then. Quote
stax Posted December 28, 2005 Author Posted December 28, 2005 That's great, if there wasn't the MD plugin problem and the up/down key hassle I would be completely happy now Quote
