Scheduled recording doesn't work with 3.2.3
Roope
I updated my DVBViewer version yesterday and found out I cannot do scheduled recordings anymore. Nothing happens when the recording is supposed to start!
Scheduled recordings worked fine with 3.2.2. Options->General->Timezone shows correct time.
Other: DVBViewer starts with video paused.
System:
Win XP SP2
Twinhan Vision Plus Mini-cab (2.603 drivers)
System:
Win XP SP2
Found the setup file for DVBViewer 3.2.1 and downgraded my DVBViewer version. Everything's back to normal now, just tried to do a scheduled recordidg and it started normally.
you only have to use the new sheduler and it will work
I made complete clean install of 3.2.3, and scheduled recordings work some times. It seems that at least those recordings that are repeating, do not work. It just makes a file that is 1 kB. And those unsuccesfull recordings are sent from the EPG window.
Edited by Jiini
