Harryo Posted September 20, 2005 Posted September 20, 2005 I have been checking the transponder configuration settings looking at the Terrestrial set-ups for Australia, Europe and Taiwan. I notice that each has what appears to be a code:- Australia - 0=47 Europe - 0=60 Taiwan - 0=51 Are the above 'country specific codes' and if they are what is the code for the United Kingdom? I want to set-up a scan for the United Kingdom Terrestrial channels (Freeview). I want to create a UK transponder configuration file based on the European one, hence the need to know if these are codes or whether I am wrong about what the above represent. Cheers - Harryo Quote
Griga Posted September 20, 2005 Posted September 20, 2005 No, that's a counter (number of entries). If you want to edit transponder list files, download TransEdit from the members area (provided that you've purchased DVBViewer Pro). Doing it manually is a hard job Quote
Harryo Posted September 20, 2005 Author Posted September 20, 2005 No, that's a counter (number of entries). If you want to edit transponder list files, download TransEdit from the members area (provided that you've purchased DVBViewer Pro). Doing it manually is a hard job <{POST_SNAPBACK}> Thank you for the advice, I appreciate it. I have purchased DVBViewer Pro so will download TransEdit and give it a whirl. Cheers - Harry Quote
