Twinhan Starbox Remote Plugin
i finished the remote support for the twinhan usb dvb-t and -s boxes. The usage is simple:
1. extract the plugin into the plugins folder
2. enable the Twinhan Plugin under Options->Input->Input Plugins
3. Assign the remote keys under Options->Input.
Christian
  • 4 weeks later...
  • 3 months later...
Perhaps it's my fault I don't know...
...Is it possible to get an update of this very important plugin?
I have installed it as requested, restarted & rebooted, but it still does not work properly. I can select the device, but in the inputs there are just keyboard shortcuts. The buttons work funny, e.g "channel up" increases audio volume.
Some buttons i can "teach", but not all.
  • 4 months later...
still no update?
plz plz - we want an update :'(
  • 1 month later...
maybe i'm only a very lucky person - i don't know - but in my case the twinhan remote works without any plugins very fine. i simply used the input options panel and clicked on the learn button and assigned all the actions to the remote. i didn't need antything else for it...
