esackbauer Posted September 30, 2005 Posted September 30, 2005 Hello all, I am using DVBViewer 3.2.3 with latest dvbsource 2.4.2. When I go to OSD Menu and select "Channels" (Kanäle) and return to fullscreen, the EPG info at bottom of screen is displayed always and can only be closed manually. Also when I change channels, EPG info stays always on screen and will not go away after some seconds. In addition, the volume indicator is not displayed anymore. After restarting DVBViewer, everything is back to normal, until I go again to the OSD Channels. Im using PowerDVD6, and tested it with VMR7 and VMR9. Regards Mundl Quote
Guest Lars_MQ Posted September 30, 2005 Posted September 30, 2005 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
esackbauer Posted October 1, 2005 Author Posted October 1, 2005 Problem solved in version 3.2.4 Cheers, Mundl Quote
