Version 3.2.4 with USB2 BDA device
cockers
Hi there,
Hardware:
VIA M2 1000 Mini-ITX mobo
512 RAM
Onboard Graphics & Sound
NEC USB2 controller
VIA USB2 Controller
Sigma Designs XCARD PCI Device
Wireless PC Card
Hauppauge WinTV Nova-t USB2 BDA receiver (using NEC USB2 Controller) - I added this controller after some reports of the VIA controller being less than stable.
Software:
XMEDIA Player
WinTV2000
DVBViewer 3.2.3
TVedia 3.4
Progdvb 4.56.2
Problem:
Select BDA device at options/directx
Apply
Select channelist/channel scan
Select Terrestrial (EUR) - I am in the UK
Scan
Result: No channels found
I have used all available tuning spaces from BDA Config, all with the same result.
I have also tried the Transedit MMC scanner, to the same effect.
I guess the Nova-T USB2 may have 'damn crappy driver', which would not be all that surprising, given my previous experience with Hauppauge products.
If I use WinTV2000 to scan, it finds all available channels.
Interestingly, If I use ProgDVB version 4.56.2, which has a beta BDA module, I am able to scan and view channels. However, it is not all that stable (BSOD's a fair bit), and is not a patch on DVBViewer.
MPEGDecoder.txt
Setup.xml
DxDiag.txt
