Pro doesn't save channellist
Griga
Here is a work-around for the issue
"DVBViewer Pro 3.2.3 doesn't save new channels after scanning"
Launch the program SaveChannels.exe (download) immediately after having applied changes in the DVBViewer's channellist window (manually or by scanning).
SaveChannels.exe lets DVBViewer Pro save the file channels.dat. It has to be done before re-opening the channellist window.
DVBViewer Pro wrongly resets a "channel list has been changed" flag each time when you open the window, which prevents saving (until next change).
