Dual
Marekf
I don't know if it would be possible to add Dual function to DVBViewer. Some movies are broadcasting in original language too.
Sorry for my english.
you can edit the audio pid in the channel list manually, normaly if a channel does brodcast a second language you just have to add 1 to the actual audio pid. To make sure you can check the settings with Lyngsat or SatcoDX
