EPG recording bug?
A380
I have a problem with the "send to PVR" function in the EPG window.
I want to record "N-TV Reportage" on the N-TV channel on Astra. When I select the entry starting at 00:15 ending at 01:00 and send it to PVR then it shows there with a starting time 23:45.
In the settings I selected 15 mins pre record and 15mins after record. So it should start at 00:00. I tried the same with other entrys and there everything is fine. Just at this time it doesn't work correct. Maybe there is some bug becaus of day change?
Which Version do you use. It seems to be a very old bug.
