Advanced channel scan
LSD
When scanning with the built in scanning routine some transponders get accidentially scanned twice if the tuner is able to lock on to two simmilar frequencies corresponding to the same transponder. Increasing the step width can drop some transponders.
Would it be possible to implement sat-ini based scanning which only scans transponders found in a text file, this would also speed up the scanning process dramatically :-)
And what about adding a 12V switch signal routed to a com port to the LNB selection, some people do have more than 4 LNBs.
I think is a very good ideea.
