How can view full EPG ???
lancillotto
Hi, is it possible view full EPG (not only two events) for a channel ??
Full epg for the channel is trasmitted in MediaHighway.
I have tried to export in XML but with the plug-in for DVBViewer I am not viewed full epg.
P.S.: Exuse me for my bad english.
yes , export it as HTML
You can only see what the TV stations are sending. If they send only 2 days you cant see more.
The TV station are sending only 2 events, but via MediaHighway I see with this software http://scaistar.altervista.org/phpBB2/viewtopic.php?t=6090 one week of epg ! With this software (Sky2Epg) I export in XML format and I tried to import it in DVBViewer . Do you understand me ??
no chance to import EPG from an other programm
no chance
...why not? :)
...the Lars_MQ's "XMLTV Importer" is a (beta) plugin specifically developed for the XMLTV output of this app...
:) all
argh ... i forgot sorry
