Simultaneous recordings
Aztech
For obvious reasons the board can't tune to multiple transponders simultaneously, however is it possible to access all/some of the services on the same transponder concurrently? So you could for instance be recording two radio stations at the same time. I assume it's technically possible considering the board dumps the entire transport stream on to the software. :D
Cheers.
Guest hackbart
since you only have one tuner it is impossible to tune 2 or more different transponders in.
But you should be able to record two radio streams (if they are both on the same transponder). For these things you can use the recorder tool, located in the commercial DVBViewer package.
Christian
Hi Christian, Thanks for that.
Is there a maxium of two streams or could you for instance have 3 or 4 going simultaneously?
Guest hackbart
theoretically you should capture the whole bandwith allowed by the pci specs. But somehow B2C2 does not allow this; maybe i'm wrong with that but if you dump data pins you can also dump more than one...
Christian
