inksticks Posted October 27, 2005 Posted October 27, 2005 I have succesfully setup the skystar2 on my pc but when Setup4PC is running and is not tuned to a channel my sound shutters a bit. I believe the easiest solution would be to just have the Setup4PC program default to the right settings when it loads but I can't seem to figure out how to set this. Here are the settings I would like loaded when Setup4PC starts. Satellite AMC4 Frequency = 11822 Symbol Rate = 5700 FEC 2/3 or AUTO Polarization = Horizontal LNB = 10750 with 22khz If someone could tell me how to have Setup4PC default to this when loading I would appreciate it. By the way I use MediaPortal as my software for viewing and that works fine. However, if I want to listen to music or watch a video with any software I have to manually set Setup4PC the frequency above on AMC4 (this turns the status indicator for setup4pc from red to green and my audio begins to work fine) Help would be much appreciated. Quote
Klausing Posted October 27, 2005 Posted October 27, 2005 disable setup4pc in autostart DVBViewer dont need it. Quote
inksticks Posted October 27, 2005 Author Posted October 27, 2005 disable setup4pc in autostart DVBViewer dont need it. <{POST_SNAPBACK}> I don't use DVBViewer. I use Media Portal as stated in my previous post however I followed your advise and the problem seems to be fixed for Media Portal also. Thanks very much. Quote
Klausing Posted October 27, 2005 Posted October 27, 2005 I don't use DVBViewer. I use Media Portal You know in which forum you are?But it was a pleasure to help a MediaPortal user Quote
