freeekbert Posted November 1, 2005 Posted November 1, 2005 (edited) Hi I recently bought DVBViewer 3.2.4 and I don't like to watch TV on my computer. So I decided to use the TV-Out connector on my GeForce 4 TI and watch TV on a real big screen. The problem: There is no picture at all on the TV screen, it's just black. I've tried several possible solutions (including changing DirectX output to "Unchanged" and other filters but nothing worked.) I searched the forum but I didn't even find anything useful about that. My system: AMD Athlon XP 1600+ WinXP 250GB Hard Disk 512MB DDR-RAM Filters: MPEG2 Video Decoders: --------------------- InterVideo Video Decoder: 00700000 CyberLink Video/SP Decoder: 00600000 CyberLink Video/SP Decoder: 00600000 MPEG Audio Decoders: --------------------- Moonlight Odio Dekoda: 24111981 MPEG Audio Decoder: 03680001 InterVideo Audio Decoder: 00700000 CyberLink Audio Decoder: 00602000 CyberLink Audio Decoder: 00601000 Nero Digital Audio Decoder: 00600000 Any further information is attached. [no .log available] Thanks for any help freeekbert [EDIT] I've just tried to change the filter while the DVBViewer window is on the TV screen and now there is a picture. But: as soon as I double-click on it for fullscreen the fullscreen moves back to the PC monitor. And: I use DualView with my PC monitor as primary display and the TV screen as secondary display. Setup.xml Edited November 1, 2005 by freeekbert Quote
Klausing Posted November 2, 2005 Posted November 2, 2005 install Sonic or DVDExpress decoder fromyour cd and set an video an audio decoder in your options. For instance DVDExpress. Quote
freeekbert Posted November 2, 2005 Author Posted November 2, 2005 install Sonic or DVDExpress decoder fromyour cd and set an video an audio decoder in your options. For instance DVDExpress. Thanks for the reply. I don't have a CD, downloaded it from www.DVBViewer.com Do you mean Sonique? That's what I found in member's area. Where should I get DVDExpress from? I actually tried to set the decoders manually, but that didn't work either. At present I'm using VMR9 filter, Intervideo Video Decoder and MPEG Audio Decoder. Quote
Klausing Posted November 2, 2005 Posted November 2, 2005 i spoke about the driver CD which comes with your card Quote
