mittern8 Posted November 5, 2005 Posted November 5, 2005 (edited) I noticed some minor problems: after switching from one skin to another the menu bar doesn't work at all(exept the minimize button) after using a skin "no skin" can't be set changing the volume using the mouse wheel doesn't move the slider in default skin visual plugins aren't working As far as I remember at least three of the problems occured in earlier versions too and had already been fixed. <EDITH> Added two additional topics </EDIT> Edited November 5, 2005 by mittern8 Quote
Guest Oliver Posted November 5, 2005 Posted November 5, 2005 1. Just tested: Everything's okay here. Quote
Guest Lars_MQ Posted November 5, 2005 Posted November 5, 2005 2. Just tested: Everything's okay here. Quote
mittern8 Posted November 5, 2005 Author Posted November 5, 2005 (edited) 1. Just tested: Everything's okay here. <{POST_SNAPBACK}> Try changing from default to defgold and back to default. After that the menu bar doesn't work here ... Seems as if the skin engin wouldn't like a two times change. 2. Just tested: Everything's okay here. <{POST_SNAPBACK}> Neither Punkie nor Corona want to show up here. Tried overlay, unchanged, VMR7, VMR9. But this is really a minor prob. Edited November 5, 2005 by mittern8 Quote
Guest Oliver Posted November 5, 2005 Posted November 5, 2005 1. Tested again considering your hint: Still no problem here. Quote
mittern8 Posted November 5, 2005 Author Posted November 5, 2005 1. Tested again considering your hint: Still no problem here. <{POST_SNAPBACK}> May be I should have mentioned that "Hide Display in Radio Mode" is activated Take a look at the attached DVBViewer.log for further info. But now I'm at least able to change from skin to "no skin" and the volume slider works too. DVBViewer.log Quote
