Integration Of An External Player
desasterdan
Hi christian,
i think it would be a good idea to make it possible to use an external mediaplayer like zoomplayer instead of the inegreted standard player.
regards.
Daniel
Guest Lars_MQ
Interesting, i think it's a bad idea :D
wirklich sehr geistreicher Komentar!
as I know it is not possible to:
- change audio tracks.
- use Chapter information.
in other words, how do you think about full AVI / mkv /ogg, support?
i'm realy tired to change between Z.P. and DVBViewer.
Daniel
as lars already said: it is a bad idea.
I wonder why you wrote this? The DVBViewer is as capable to play ogg, mkv or whatever you want. The only thing you have to keep in mind is that you should install a directshow filter/splitter which is required for this.
By the way the ability to change Audio Tracks is since more than 2 years inside !
Christian
