IRa Posted November 9, 2005 Posted November 9, 2005 OSD weatherdata does not change days anymore. It is always showing the forecast from sunday to wednesday, in 3.2.4 it worked OK. Quote
Guest Lars_MQ Posted November 9, 2005 Posted November 9, 2005 Did you try to download the data manually? (Button on the left side) Quote
IRa Posted November 10, 2005 Author Posted November 10, 2005 Did you try to download the data manually? (Button on the left side) <{POST_SNAPBACK}> If you mean the refresh button it does not effect in any way Quote
Guest Lars_MQ Posted November 10, 2005 Posted November 10, 2005 I tested it no problem at all. Have a look into the weather folder there is a xml file (with XX in the name), and rename it to some else. Then please try again calling the weatherpage in the OSD. Quote
IRa Posted November 10, 2005 Author Posted November 10, 2005 I tested it no problem at all. Have a look into the weather folder there is a xml file (with XX in the name), and rename it to some else. Then please try again calling the weatherpage in the OSD. <{POST_SNAPBACK}> I thing I find the problem, those files where with the date of 6th December 2005 (I changed the PC calender by misstake some days ago and noticed it later at the same day) I thing that confused the OSD. I copyed those files from the directory of older version and now it works again. Thank you for the hint. Quote
