Make photo of TV
alfa
It's possible make a photo of display and save it in a jpeg format or in another format ?
Guest hackbart
unluckily not yet, but i'm working on. After the new renderer filter is finished it is possible.
Christian
Hello,
try this.
Active the DVBViewer window. Press alt + print buttom at the same time. Open a graphic program like paint shop. Take the edit menu and insert the clipboard content. Now you can optimize the picture and save it.
Hopefully this help you.
Guest hackbart
well this is only working if the overlaymixer is not available, otherwhise you would only see a blank image. The new renderer will definitively have a snapshot feature in, but till then you have to wait. :D
Christian
if you have it recorded:
what about HyperSnap capturing software, or a little worse is zplayer.,
very good is also windvd 4 for capturing.
Guest hackbart
i hope these problems are gone whit the new xvr renderer.
Christian
