musukebba Posted November 17, 2005 Posted November 17, 2005 Where might we find the files saved by using the 'Screenshot' option (right-click in the TV display window -> 'View' -> 'Screenshot')? Can the destination directory be changed somewhere in the 'options' menu? Searched on the forum and through the help files, but nothing found... Quote
IRa Posted November 17, 2005 Posted November 17, 2005 Where might we find the files saved by using the 'Screenshot' option (right-click in the TV display window -> 'View' -> 'Screenshot')? Can the destination directory be changed somewhere in the 'options' menu? Searched on the forum and through the help files, but nothing found... <{POST_SNAPBACK}> I have always wondered what is it for and when it will work. I have it always grey and it can not be used. Does it need some plugins or what ? Is it possible to take screenshots? Quote
Lower Posted November 17, 2005 Posted November 17, 2005 Where might we find the files saved by using the 'Screenshot' option (right-click in the TV display window -> 'View' -> 'Screenshot')? Can the destination directory be changed somewhere in the 'options' menu? Searched on the forum and through the help files, but nothing found... <{POST_SNAPBACK}> I have always wondered what is it for and when it will work. I have it always grey and it can not be used. Does it need some plugins or what ? Is it possible to take screenshots? <{POST_SNAPBACK}> Select another video render (not the vmr9) in the directX settings of the DVBViewer and it will work. Use for example the overlay. Quote
Guest Lars_MQ Posted November 17, 2005 Posted November 17, 2005 Don't use Overlay use VMR or unchange. The pictures will be placed into the capture folder (have a look at your options where it might be... Quote
musukebba Posted November 17, 2005 Author Posted November 17, 2005 (edited) Thanks - but none of those (conflicting) suggestions work: Overlay - not available (greyed out). Unchanged - option available; no image in 'capture' VMR7 - option available, makes sound like camera when used; no file in 'cature'folder. VMR9 - option available - no image in 'capture' Tried all settings with 'apply' and also restarting DVB-V. Also with another MPEG2 decoder (Nvidia and Elecard) The image isn't on the clipboard either.. Edit: following the next post I tried VMR7, and the .png file appears in the same file as recordings (rather than 'capture' folder). Many thanks! Edited November 17, 2005 by musukebba Quote
IRa Posted November 17, 2005 Posted November 17, 2005 Thank you for advices, it works!! settings: Overlay - not available (greyed out). Unchanged - option available; no image in 'capture' VMR7 - option available, but no sound like camera and no TV picture at all VMR9 - option available - sound like camera and *.png files appears in same recordings folder as video recordigs. Quote
