Piddump
Aztech
Hi there,
Does piddump operate for radio, whenever I try it I recieve this error
"Exception EInOutError in Modul piddump.exe bei 0000DF45.
Ung³ltiger Dateiname."
Could somebody confirm the commandline parameters, I'm using the following :-
piddump -f 11798 -s 27500 -l 10600 -e auto -o h -k 22 -p -p ..\Capture\test.ts
Cheers,
Az.
Guest Michael
Hi there,
piddump -f 11798 -s 27500 -l 10600 -e auto -o h -k 22 -p <first> -p <second>  ..\Capture\test.ts
Cheers,
Az.
that means in german INVALID FILENAME....
maybe that's the reason :rolleyes: ?
Hrm, when I change the filename I get :-
C:\Program Files\DVBViewer>piddump -f 11798 -s 27500 -l 10600 -e auto -o h -k 22
-p 2348 test.ts -f 11798 -s 27500 -l 10600 -e auto -o h -k 22 -p 2348 test.ts
2348
0
With a 0kB file :blink: Same no matter how many PID's I list.
2348
0
You can forget piddump at the moment.Wait for the next release.
It may work or not.
Ex. if you record pid 100 101 on one frequency and then record 102 103 on same frequency the result will be that it the last record contain previously selected pids.
Cu Flepp
