mitsu Posted November 22, 2005 Posted November 22, 2005 Wouldn't it be easy to change the tuner according to the channel? I have two cards and I change between cards in the options menu. I have only one channellist where I have channels for both tuners. I would imagine that it would be pretty staightforward to change the card according to the channel. I know that you are planning to have two DVBViewer instances running simultaneously. That might be working but feels a little bit more complicated. Would it cause unnesessary CPU load if you just record one channel at a time? Quote
Guest Lars_MQ Posted November 22, 2005 Posted November 22, 2005 This is planned for Version 4.0. Quote
SF100 Posted November 22, 2005 Posted November 22, 2005 I can use three cards at the same time with three DVBViewers (beta). Release versions just have a check if DVBViewer is already running. So that is not a problem even now. Quote
Griga Posted November 22, 2005 Posted November 22, 2005 Read more about running two instances simultaneously here: http://www.DVBViewer.com/forum/index.php?s...indpost&p=75975 Quote
