epg search in OSD
ylber
hi,
I am searching the OSD menu to search into th EPG
i found something in the osd skins folder
myepgsearch.xml
but I can't acces it into the OSD menu
it should be in the windowdef.xml ?
can someone help ?
thanks
ylber
Edited by ylber
Guest Lars_MQ
This is just a search more screen. Means you select a EPG entry in OSD-lists or timeline and press OSD-Blue for context menu and select "find more...".
I'm planning on providing a complete OSD-Based search in EPG but this will take some time :)
  • 2 months later...
