boborg Posted November 22, 2005 Posted November 22, 2005 (edited) I could use a way to schedule a saving of the EPG as a XML file. Edited November 22, 2005 by boborg Quote
Guest Lars_MQ Posted November 22, 2005 Posted November 22, 2005 XML is only a container format. It says nothing about the Dataformat or contained data. You have to be more specific. Quote
kevl Posted December 10, 2005 Posted December 10, 2005 Hi Is it possible to have DVBViewer dump its collected EPG data into an xml file compatible with the output of XMLTV files? I would like to have DVBViewer download EPG info at a scheduled time and then save the data in a form compatible with XMLTV so that I can use the data in other HTPC apps for use with non DVB TV cards. If XMLTV data is not possible then any text based file format - that I can then convert - would be fine. Are there tools to accomplish this? Kev Quote
Guest Lars_MQ Posted December 10, 2005 Posted December 10, 2005 You could always write a script yourself with the COM-Interface of the DVBViewer and vb-Script. You can create with this combination nearly every wanted fileformat. Quote
