mrr19121970 Posted June 19, 2012 Posted June 19, 2012 At best the TV gives an error message saying there is no playable content. Worst is the TV crashes and hast to be restarted. LOG file attached with UPNP debugging enabled. support.zip
mrr19121970 Posted June 19, 2012 Author Posted June 19, 2012 This one was created when the TV crashed.... support.zip
mrr19121970 Posted June 26, 2012 Author Posted June 26, 2012 Looking at the English and German forums, it seems I'm not alone in this DVBViewer & Samsung TV issue. I'm wondering if there is any further information I can provide the DEVS to fix this issue?
Gioxy Posted June 26, 2012 Posted June 26, 2012 IMO there's nothing to fix, simply DLNA isn't UPnP but a special and specific subset of it, while RS is "only" UpnP, not DLNA... In simple words, DLNA can be defined as “UPnP A/V with restrictions“. Using plain UPnP A/V, a server can share any kind of file (being binary, audio file, video file, text file like subtitle, or even a Word or PowerPoint presentation, whatever …). All it does after all, is sharing a file through HTTP with its associated MIME type, just like any HTTP server (Apache …) would do. It was then up to the client/player to determine whether or not it can handle the stream. This was quite too simple for DLNA folks. They have decided that only a numerous number of files are worth being shared. As a result, they’ve decided to restrict the protocol so that only some specific file extensions, but also containers and audio/video codecs combination can be used. source ...obviously I also whould be happy if RS will become DLNA compilant too...
mrr19121970 Posted June 29, 2012 Author Posted June 29, 2012 (edited) Thanks for that link. I wasn't really aware there was a differnce. I tried another DVB live streaming software which is DLNA compliant and the works now. Shame that DVBViewer Recording Service can not also stream DLNA, as this would then be the icing on the cake. Update According to the WIKI SamsungTVs are supported. Source Der Service enthält einen UPnP/DLNA AV Server mit dem LiveTV, Aufnahmen, Filme, Musik oder Photos an UPnP/DLNA fähige Geräte (Samsung TV, Sony PS3 etc.) oder Programme (z.B. xbmc) gestreamt werden können Edited June 29, 2012 by mrr19121970
Gioxy Posted June 29, 2012 Posted June 29, 2012 That seem a (too) reduced version of a old RS changelog (source) that more frankly say: Add: UPnP: The Recording Service can now stream via UPnP/DLNA AVI, MKV, WMV and ASF files too.◦There is no transcoding, it depends on the player if the files can be played. Sometimes certain parameters need to be adjusted for some devices so they work correctly. As example the SamsungTV needs a special mime type so it can play mkv files. These adjustments/settings will have to be examined and created on a case by case basis. This will take place in the forum. Currently tested with a Samsung LCD TV, Popcorn Hour A100/A200 and PS3 (no mkv possible). I'm sure you well know that "Samsung LCD TV" are based on many different kind of HW and SW, even inside the same series, and - indeed - Lars talk about "a" Samsung LCD TV, not "all" Samsung LCD TV; ...so most probably your TV unluckily fall in later cases: "certain parameters need to be adjusted..." and "These adjustments/settings will have to be examined on a case by case basis" and so on... Can't find ATM, but I seem to remember that someone has already posted a parameter list for his specific TV set...
Gioxy Posted July 1, 2012 Posted July 1, 2012 Good news from RS 1.10 changelog: •Fix: UPnP: Fix for Samsung E Series doesn't display the UPnP lists. Hope that fix also for your TV...
mrr19121970 Posted December 25, 2012 Author Posted December 25, 2012 Thanks for the tip. Wasn't in the forum for a few month. Just updated to 1.23 and I can confirm I can watch TV again. Great. Thanks.
tempoplus Posted May 11, 2013 Posted May 11, 2013 can you tell how to set this up? i got the same config here
