Rob66 Posted December 30, 2012 Posted December 30, 2012 I have install DVBViewer 5.0 > Option > OSD > I cannot disable this function anymore. In version 4.9.6.20 it was built-in, PLS Help Quote
Rob66 Posted January 12, 2013 Author Posted January 12, 2013 Now Included supporttool.zip Additional information TBS 6928 PCIe DVB-S2 TV Tuner CI Card Windows 8 Pro 64 Bit ASUS F2A85-M PRO CPU AMD A10-5800K (Incl. Graphics) Memory 8 GByte SSD 64 GByte Hoop you can help me... Thx Robert 1 Quote
QBox User Posted January 12, 2013 Posted January 12, 2013 It looks like the Option has been removed in V5.0, though there's nothing in the changelog. German forum post 1 Quote
SnoopyDog Posted January 12, 2013 Posted January 12, 2013 Yes, it is not possible to deactivate the OSD in version 5.x. Why would you like to disable it? Quote
Rob66 Posted January 13, 2013 Author Posted January 13, 2013 Why would you like to disable it? Reason, I am using only on my PC. I don't need OSD on my screen.. .It is interrupting / delay my video work.. Attention If I am install V5.0.0.0 over V4.9.6.20 > Result OSD is still disable (Sup price) When I make a new install, so delete the old setting before, then the OSD function disable is not available. So OSD can't disable any more. Tip, for designers, Connect the OSD on the present of the IR remote control during the installation... Thx Robert 1 Quote
starman345 Posted February 2, 2013 Posted February 2, 2013 I don't care for the OSD either, I spent a lot of time trying to find how to disable then saw this thread...just a small note in changelog would save people a lot of time. 1 Quote
hackbart Posted May 2, 2013 Posted May 2, 2013 This is not working, disabling the OSD also disables the COM Plugin Interface and there are more unwanted side effects. To be honest there is absolutely no reason to disable it. Quote
Tjod Posted May 2, 2013 Posted May 2, 2013 To disable the OSD and things which are connected to the OSD e.g. subtitles start menu > DVBViewer > Support > Tweaker > Enable the OSD Quote
