myExtendedExit, myActions, mySleeptimer, myProcesstaks, myBackup
nuts
this thread is for english questions about some small scripts I created for the DVBViewer Pro.
German thread with download and "how to" in german: http://www.DVBViewer.tv/forum/topic/57636-myextendedexit-myactions-mysleeptimer-myprocesstaks-mybackup/?p=444219
Currently there is no english tutorial available how to use this script, but feel free to ask and I will try to help you. :)
Some quick words how to install these script:
1. download myscripts.zip from here: http://www.DVBViewer.tv/forum/topic/57636-myextendedexit-myactions-mysleeptimer-myprocesstaks-mybackup/?p=444219
2. unzip myscripts.zip
3. run my_scripts_install.bat to create OSD entries for myExtendedExit, myActions and mySleeptimer
Greetings
Nuts
Edited by nuts
Hi Nuts,
Many thanks for the language modification !
I've also another question:
Currently i'm struggling with windows 10 wakeup's from windows updates. I've tested many things , but Windows 10 keeps waking up for reboot. On the internet there are many post to modify this behaviour like this:
http://superuser.com/questions/973009/conclusively-stop-wake-timers-from-waking-windows-10-desktop/973029#973029
But none are working fine for me.
So i'm thinking about to let windows 10 do , what it want't to do : install updates / reboot.
But the only anoying is , that the CEC adapter does power on the TV.
So I would like to check , which process , wakes the PC.
Sort of this discussion is already here http://www.DVBViewer.tv/forum/topic/48290-einbindung-von-libcec/page-5 (Cinch is talking about this in German)
Currently i've autohotkey active , for this kind of aditional triggers , but I would realy like to detect the wake-up cause in your scripts.
Would you like to have a look on this ?
Many thanks !
Kind regards
Cuppie
Hm I thought my scripts should ignore wake ups by the system or tasks and react only on wake ups triggert by the user?
This doesnt work for you?
Not sure about that.
But the facts I are :
- the cec adapter sends the "power on" command to the tv.
- DVBViewer.exe is started.
In the event viewer , the wake up cause is "unknown"
But from that last , i'm sure it's the "reload" schdedule from task manger.
Currently i've exactly the same setup , with a schedule that expires tonight at 0:34.
When i use my ir-remote , to power on the tv , the wake up case in the event viewer is : "power button"
Hm ok ...
Is "extendedlog" for my scripts enabled? If yes: Could you please post the log at 0.34? Otherwise please enable logging (Extendedlog=1 in the config file).
Just forgot the correct trustees on the myscripts dir.... missed the logs...
But i've made the log manually , and just scheduled a task , with wakeup
Log with a scheduled task :
2016-03-26 20:51:52 : Exit myExtendedExit - Version: 1.0
2016-03-26 20:51:52 : run="C:\Program Files (x86)\DVBViewer\DVBViewer.exe" -x53
2016-03-26 20:51:52 : cec=on 0
2016-03-26 20:51:52 : cec=as
2016-03-26 20:51:52 : run="C:\Program Files (x86)\DVBViewer\DVBViewer.exe" -c1
2016-03-26 20:51:52 : runwait="C:\ProgramData\my_scripts\resume-DVBViewer.cmd"
2016-03-26 20:51:52 : section "Resume"
2016-03-26 20:51:52 : log=section "Resume"
2016-03-26 20:51:52 : _run_section => section=Resume
2016-03-26 20:51:52 : Func _Resume
2016-03-26 20:50:44 : shutdownmode=32
Vargettype= String
2016-03-26 20:50:44 : resume=1
2016-03-26 20:50:44 : shutdown=32
2016-03-26 20:50:44 : cec=standby 0
2016-03-26 20:50:43 : sleep=1
2016-03-26 20:50:43 : runwait="C:\ProgramData\my_scripts\sleep-DVBViewer.cmd"
2016-03-26 20:50:43 : sendcommand=12326
2016-03-26 20:50:43 : cec=standby 0
2016-03-26 20:50:43 : _run_section => section=Standby
2016-03-26 20:50:43 : myExtendedExit: cmdline[1] = Standby
2016-03-26 20:50:42 : Startup myExtendedExit Version: 1.0
C:\WINDOWS\system32>powercfg -lastwake
Wake History Count - 1
Wake History [0]
Wake Source Count - 0
Log with wake with ir-remote:
2016-03-26 20:57:11 : Exit myExtendedExit - Version: 1.0
2016-03-26 20:57:11 : run="C:\Program Files (x86)\DVBViewer\DVBViewer.exe" -x53
2016-03-26 20:57:11 : cec=on 0
2016-03-26 20:57:11 : cec=as
2016-03-26 20:57:11 : run="C:\Program Files (x86)\DVBViewer\DVBViewer.exe" -c1
2016-03-26 20:57:11 : runwait="C:\ProgramData\my_scripts\resume-DVBViewer.cmd"
2016-03-26 20:57:11 : section "Resume"
2016-03-26 20:57:11 : log=section "Resume"
2016-03-26 20:57:11 : _run_section => section=Resume
2016-03-26 20:57:11 : Func _Resume
2016-03-26 20:56:49 : shutdownmode=32
Vargettype= String
2016-03-26 20:56:49 : resume=1
2016-03-26 20:56:49 : shutdown=32
2016-03-26 20:56:49 : cec=standby 0
2016-03-26 20:56:48 : sleep=1
2016-03-26 20:56:48 : runwait="C:\ProgramData\my_scripts\sleep-DVBViewer.cmd"
2016-03-26 20:56:48 : sendcommand=12326
2016-03-26 20:56:48 : cec=standby 0
2016-03-26 20:56:48 : _run_section => section=Standby
2016-03-26 20:56:48 : myExtendedExit: cmdline[1] = Standby
2016-03-26 20:56:48 : Startup myExtendedExit Version: 1.0
Wake History [0]
Wake Source Count - 1
Wake Source [0]
Type: Fixed Feature
Power Button
So I think it should be possible somehow , to detect the poweron method.
And when this is possible , only when the pc is woken up by power button , the cec command will be send , to power-on the tv.
When the PC is woken by schedule , the cec command will not be send ( and maybe some schutdown schedule will be set)
Cuppie
Hm ok seems like we need another testversion with addional logging. :(
I will upload it soon here.
Sorry for my interferrance. Just wanted to present my Autohotkey code im using for this exact thing. It might give some clues to the problem. Windows 10 messages are a bit different. Im monitoring these messages with success to accomplish this very exact thing. Important to clear the memory regularly.
onmessage(0x11, "on_shutdown") ;WM_QUERYENDSESSION
onmessage(0x218, "on_shutdown") ;WM_POWERBROADCAST
;---------------------------------------------------------start timer to clear memory every 10 minutes. end autoexecute.
settimer, emptymem, 60000
return
;---------------------------------------------------------function to be called on shutdown or log out etc.
on_shutdown(param1, param2) {
if ((param1 = 0) && (param2 = 0)) ; shutdown
AddToBOF("log.txt", a_yyyy "-" a_mm "-" a_dd " " a_hour ":" a_min " - " "System shutdown.`r`n")
if (param2 = 1073741824) ; restart
AddToBOF("log.txt", a_yyyy "-" a_mm "-" a_dd " " a_hour ":" a_min " - " "System restart.`r`n")
if (param2 = -2147483648) ; log out
AddToBOF("log.txt", a_yyyy "-" a_mm "-" a_dd " " a_hour ":" a_min " - " "System log out.`r`n")
if (param1 = 4) ; hibernate
AddToBOF("log.txt", a_yyyy "-" a_mm "-" a_dd " " a_hour ":" a_min " - " "Entering system hibernation.`r`n")
if (param1 = 18) ; resume from hibernation scheduled timer/task
AddToBOF("log.txt", a_yyyy "-" a_mm "-" a_dd " " a_hour ":" a_min " - " "Resume from hibernation.`r`n")
if (param1 = 7) { ; resume from hibernation from power button
;---------------------------------------------------------clear memory.
emptymem:
dllcall("psapi.dll\EmptyWorkingSet", "UInt", -1)
return
Edited by majstang
Here we go. :)
@cuppie: Could you please do some test with this versions @Win10?
I am interested in a log with wake up triggert by user input (i.e. powerbutton) and a log when the system resumes by task without user input.
Anyway I am doing this:
Func _MY_WM_POWERBROADCAST($hWnd, $msg, $wParam, $lParam) ; receiving WM_POWERBROADCAST messages
If $writelog Then _FileWriteLog($my_scripts_log, "Debug wakeup - $wParam: "&$wParam, 1) ;debug
Switch $wParam
Case $PBT_APMRESUMESUSPEND ; this message is sent after PBT_APMRESUMEAUTOMATIC if the resume is triggered by user input, such as pressing a key
; $PBT_APMRESUMESUSPEND = 0x00000007 ;7 (0x7)
; erste Benutzeraktion nach dem Standby (manuelles Aufwecken zählt als erste Benutzeraktion)
If $writelog then _FileWriteLog($my_scripts_log, "$PBT_APMRESUMESUSPEND="&$wParam, 1) ;debug
If $wait4resume Then _Resume() ; run resume section after wakeup by user input (i.e. power button)
Case $PBT_APMRESUMEAUTOMATIC ; This message is sent every time the system resumes.
; $PBT_APMRESUMEAUTOMATIC=0x00000012 ;18 (0x12)
If $writelog then _FileWriteLog($my_scripts_log, "$PBT_APMRESUMEAUTOMATIC="&$wParam, 1) ;debug
If $wait4resume Then HotKeySet("^r", "_resume") ; special for imon devices (tüftler) - should not do anything if you don't use the "strg+r" hotkey
EndSwitch
EndFunc ;==>_MY_WM_POWERBROADCAST
I think I did it right? Maybe something special with Win10 (can not test @Win10 ...)?
@majstang What do you think?
myExtendedExit.zip
Hi nuts!
The powerbroadcast messages seem to be the same regardless of Windows version, however in my case on my old Win7 system I got logs for both resume hibernate from scheduled timer/task and resume hibernate from power button by only monitoring PBT_APMRESUMESUSPEND. On Win10 no more logs for resume from hibernate scheduled timer/task until starting monitoring PBT_APMRESUMEAUTOMATIC. So there seem to be a Win api handling difference at least between these OS:es. I dont know if that applies to this case though. Im not using your script cuz I like to use my own. We will see what results cuppie gets :original:
Regards
majstang
Edited by majstang
Sorry for the delay....
Still running on windows 10.
When I schedule an action with windows task manager , and enable "wake-up from sleep" in the task.
The following logs are generated from extended-exit.
To be clear , the task was scheduled at 16:21:00
2016-04-05 16:22:14 : Startup myExtendedExit Version: 1.1
2016-04-05 16:21:06 : Exit myExtendedExit - Version: 1.1
2016-04-05 16:21:06 : run="C:\ProgramData\my_scripts\resume-DVBViewer.cmd"
2016-04-05 16:21:06 : section "Resume"
2016-04-05 16:21:06 : log=section "Resume"
2016-04-05 16:21:06 : _run_section => section=Resume
2016-04-05 16:21:06 : Func _Resume
2016-04-05 16:21:06 : $PBT_APMRESUMESUSPEND=0x00000007
2016-04-05 16:21:06 : Debug wakeup - $wParam: 0x00000007
2016-04-05 16:19:58 : shutdownmode=32
Vargettype= String
2016-04-05 16:19:58 : resume=1
2016-04-05 16:19:58 : shutdown=32
2016-04-05 16:19:58 : cec=standby 0
2016-04-05 16:19:57 : sleep=1
2016-04-05 16:19:53 : runwait="C:\ProgramData\my_scripts\sleep-DVBViewer.cmd"
2016-04-05 16:19:53 : sendcommand=12326
2016-04-05 16:19:53 : cec=standby 0
2016-04-05 16:19:53 : _run_section => section=Standby
2016-04-05 16:19:53 : myExtendedExit: cmdline[1] = Standby
2016-04-05 16:19:53 : Startup myExtendedExit Version: 1.1
When I resume the pc with the ir remote :
2016-04-05 16:12:53 : Exit myExtendedExit - Version: 1.1
2016-04-05 16:12:53 : run="C:\ProgramData\my_scripts\resume-DVBViewer.cmd"
2016-04-05 16:12:53 : section "Resume"
2016-04-05 16:12:53 : log=section "Resume"
2016-04-05 16:12:53 : _run_section => section=Resume
2016-04-05 16:12:53 : Func _Resume
2016-04-05 16:12:52 : $PBT_APMRESUMESUSPEND=0x00000007
2016-04-05 16:12:52 : Debug wakeup - $wParam: 0x00000007
2016-04-05 15:55:54 : shutdownmode=32
Vargettype= String
2016-04-05 15:55:54 : resume=1
2016-04-05 15:55:54 : shutdown=32
2016-04-05 15:55:54 : cec=standby 0
2016-04-05 15:55:53 : sleep=1
2016-04-05 15:55:49 : runwait="C:\ProgramData\my_scripts\sleep-DVBViewer.cmd"
2016-04-05 15:55:49 : False
2016-04-05 15:55:49 : We intercepted a COM Error !
Number is: 80020006
Windescription is: Onbekende naam.
2016-04-05 15:55:49 : sendcommand=12326
2016-04-05 15:55:49 : cec=standby 0
2016-04-05 15:55:49 : _run_section => section=Standby
2016-04-05 15:55:49 : myExtendedExit: cmdline[1] = Standby
2016-04-05 15:55:49 : myExtendedExit Error: _DVBV-Connect
Number is: 80020006
2016-04-05 15:55:49 : Startup myExtendedExit Version: 1.1
as far as i can see there is no diffence between wakeup types.
last week I've also been searching with google , for triggers in autohotkey or autoit to detect the wakeup cause.
The only thing i've really learned , is that I'm not the only one.
I'm currently running with these commands in my batch file "resume-DVBViewer.cmd" :
powercfg -lastwake | find "Power Button" > nul
if %ERRORLEVEL% neq 1 (
"C:\ProgramData\my_scripts\tv-on.exe"
Start /D "C:\Program Files (x86)\DVBViewer" /B DVBViewer.exe -c1
GOTO EOF
powercfg -lastwake | find "Realtek PCIe GBE Family Controller" > nul
copy C:\ProgramData\my_scripts\dummy.txt C:\ProgramData\my_scripts\reboot-after-wol.txt
GOTO EOF
) ELSE (
copy C:\ProgramData\my_scripts\dummy.txt C:\ProgramData\my_scripts\reboot-after-schedule.txt
Start /D "C:\Program Files (x86)\DVBViewer" /B myActions.exe delayed-reboot
GOTO EOF
:EOF
When booting the pc/windows , the following batch file is run (only when booting , not when resuming) to detect the boot cause.
This is when updates are installed , or when I manually woken-up the pc to do some maintenance.
In these cases the pc will be set in sleep mode.
if exist C:\ProgramData\my_scripts\reboot-after-wol.txt (
ping 127.0.0.1 -w 1
del C:\ProgramData\my_scripts\reboot-after-wol.txt
"C:\Program Files (x86)\DVBViewer\myExtendedExit.exe" Standby
GOTO EOF
if exist C:\ProgramData\my_scripts\reboot-after-schedule.txt (
del C:\ProgramData\my_scripts\reboot-after-schedule.txt
ping 127.0.0.1 -w 1
GOTO EOF
Somewhat difficult but it seems to be working as expected:
1- When the PC is woken-up by IR or power button : function normally
2- When the PC is woken-up by scheduled task : wait 30 minutes , and reboot (do not start DVBViewer , do not power-on tv)
This is when windows updates are installed or other windows scheduled tasks.
3- When the PC is woken-up bij WOL : do not start DVBViewer , dont do anything.
This is when I do remote maintenance.
Puuuh that's not what I expected at all. :(
Thanks for your test, but it will get hard to fix without a Win10 system.
This will take some time sorry.
Nuts, no problem. I really have respect for your work , and the sharing of your knowledge.
Nuts,
Last night I saw another issue. This time with sleeptimer.exe.
When the timer is completed , There is no message at all. In my setup , the pc is set in standby without any message or warning.
In older sleeptimer versions (not sure what version exactly) in the last minute was a warning , and possibility to stop the "shutdown action"
Roel
Nuts,
Ah ok. That's a bug ...
Try this testbuild. :)
I create another testbuild with more logging for powerbroadcast messages.
Could you please repeate your test (wakeup by task and user input)?
mySleeptimer.zip
myExtendedExit.zip
Edited by nuts
