Search the Community
Showing results for tags 'channel list'.
Hello. I really like DVBViewer but i miss the enigma of one view. Will DVBViewer be able to set this up? I think many people will like it. Channel list
DVBViewer's Skin similar to DVB Set Top Box's Menu Needed
Reza Sadeghi posted a topic in Suggestions & Ideas
Hi there. using latest DVBViewer v5.3 on system connected to TV via HDMI but Skin just like other DVB STB's or Satellite Player Receivers needed. because usually we are far from TV so can't watch DVBViewer Menus correctly easily, I thought those Channel's Names on Channel List inside DVBViewer's Default Skin is very small. we're going to blind to try to watch Channel Names from distance about 5 meter from TV and furniture. I know it is developed for PC or Desktop so users sit front of Monitors but in this situation described (system connected to TV) using DVBViewer is not as easy of those front monitors. Please add some Skin similar to Set Top Boxes with very large Menu featured at least just to change Channels. help to feel of use a professional real Set Top Box connected to TV. maybe just Skin needed. support.zip -
Hello is there a way to attach the channel list to the main window? (make it into one window) i looked every where i coud'nt find out how honestly it looks retarded and old like this, dose anyone know how?
Hi all, I am aiming at, seemingly, very simple task: I would like to export the channel list from DVBViewer to a text file, and I would like to have the channel numbers included in the list. So I can print the list of my 3000 channels and have them handy when I want to switch the channel with my remote by simply dialing a relevant number. I keep failing, however, to include the channel numbers in the .csv export file! I can have them displayed in the channel window, but impossible to export into a text file for processing and printing. I would greatly appreciate any tip or advice on this. Many thanks in advance, Kate
- 3 replies
- channel list
- channel numbers
(and 2 more)
Tagged with:
Hi would it be possible to host an online database user updated of: -Channel list per provider -Channel logos -Channel genre -Adicional channel information ex: language, country of origin
- 4 replies
- 1
- channel list
- providers
(and 3 more)
Tagged with:
