Search the Community
Showing results for tags 'set top box'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. Hi there. using latest DVBViewer v5.3 on system connected to TV via HDMI but Skin just like other DVB STB's or Satellite Player Receivers needed. because usually we are far from TV so can't watch DVBViewer Menus correctly easily, I thought those Channel's Names on Channel List inside DVBViewer's Default Skin is very small. we're going to blind to try to watch Channel Names from distance about 5 meter from TV and furniture. I know it is developed for PC or Desktop so users sit front of Monitors but in this situation described (system connected to TV) using DVBViewer is not as easy of those front monitors. Please add some Skin similar to Set Top Boxes with very large Menu featured at least just to change Channels. help to feel of use a professional real Set Top Box connected to TV. maybe just Skin needed. support.zip
