Search the Community
Showing results for tags 'direct streams'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. Hello, I am trying to stream my DVB-C for personal use using DVBViewer Media Server with the best possible quality. So I do not want to transcode. For some reason, whenever I connect to the media server and try to stream original streams, the video is always buffering. I check the upload traffic on the server and I see it never gets more than 3 Mb/s. On the other hand, if I transcode good quality, the traffic get way above 15 Mb/s but the CPU gets overloaded on the server. My question is why the direct stream is limited to 3Mb/s? Because I have good bandwidth both on the server and on the client, I would like to use the original streams. Thank you for your help. My configuration is: Server side: Windows 10-v1803, i3 2Ghz, 4GB Ram - 1600 Mhz, DVBViewer Media Server 2.1.2.0, Astrometa tuner Upload link: 500 Mb/s Client side: Kodi with DVBViewer add-on, SIPTV on smart tv, VLC.... Download link: 50Mb/s
