Hardware setup:
See, screenshot
Software setup:
DVBViewer media server 3.2.1.0
1x client running local
1x client running remote on same network
Both clients connect to the DVBViewer media server.
Both clients have transponder list 19.2, 28.2 and 23.5.
Goal:
I would like to understand when/how DVBViewer media server decides to use Tuner A or Tuner B and which software setting needs to setup.
Example 1:
Local client is locked on Tuner A and LNB 19.2, at the same time remote client should be able to lock on Tuner B and LNB 19.2
Example 2:
Local client is locked on Tuner A and LNB 19.2 and frequency 11836, at the same time the same local client should be able to lock (for recording purposes) Tuner B and LNB 19.2 frequency 11347
