Search the Community
Showing results for tags 'max decode rate'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. orangotan
    Max Decode rate
    Consider a setup with a dvb-s2 pci card with a channel being decoded directly on screen and not saved. Is the mpeg4 data coming off the dvb-s2 stream buffered over to the hard disk before its decoded...or is it buffered only in memory? What is the maximum single channel data rate that you guys managed to decode? I am asking because hard disks (non ssd ones) can be pretty become a bandwidth bottleneck for high bandwidth video streams. I got my hands on a blue ray 40mbps stream sample and tried to view it on my pc and I was only able to see only the first couple of frames off the entire sample. I am asking because I am planning to spend some money in building an dvb-s2 htpc and at the end of it I do not want to discover that I may have some hard disk bw bottlneck issue. Any related feedback would be appreciated. br Orangotan
