Search the Community
Showing results for tags 'no hardware'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. DVBViewer client works fine on Media server pc with tv card but on a remote client on the same lan I got 'No Hardware Available' error. I spent ages trying to get this to work. I solved it as follows Make sure RTSP is enabled on the server. On the client go to hardware and in devices on the right side delete any that are there then select add, then select RTSP network device. Enter the ip address of the server and the ports exactly as the RTSP settings on the server. Close and reopen the client and it worked for me. The only issue I had then was that I got sound but a black screen. I resolved this by going to settings and selecting Video output B. All ok now.
