I have been using DVBViewer successfully for several years now with my Technisat skystar 2HD, however I have now come across the following problem which I can currently find no solution for:-
I just purchased a TBS 6981 dual tuner which is installed in the same machine as the Technisat. When all three tuner modules are enabled the Technisat refuses to work. I just get a blank screen.
The TBS tuners work as they should.
When I look at device status in Recordings- and Device statistics all three tuners say they are "normal"
If I disable the 2 TBS tuners i can then tune with the Technisat again.
My system is win 7 up to date, DVBViewer 5.0 with latest sat card drivers:-
TBS 2.0.1.6
Technisat 1.1.1.502 now quite old and can't find it on their web site anymore
Can anyone shed any light on the problem?
Regards
Stu
