FelixUlm Posted December 8, 2005 Share Posted December 8, 2005 When importing SatcoDX channel lists (*.txt) into ChannelEdit, I can easily compile and edit my desired channel list, but when exporting it to *.ini format I see all StreamID-values to be set to 0 resulting in no EPG shown when selecting a channel from this list. Does any one of you have any hints how to import SatcoDX channel lists into ChannelEdit and transferring the TID information in SatcoDX lists to StreamID field in *.ini file? Quote Link to comment
Griga Posted December 8, 2005 Share Posted December 8, 2005 http://www.DVBViewer.com/forum/index.php?s...indpost&p=77681 ...and tell me if it works. Quote Link to comment
Griga Posted December 9, 2005 Share Posted December 9, 2005 Hmm, ChannelEdit doesn't use the plug-ins... but you can do it this way: import SatcoDX in DVBViewer by using the updated plug-ins -> export as INI -> import in ChannelEdit. Quote Link to comment
