Mikko-vaari Posted December 28, 2005 Share Posted December 28, 2005 Hi! I updated my DVBVPro to 3.2.6 version. I especially enjoined the fix You mentioned "[*]Fix: Recording: DVB-Subtitles are recorded in ts format now." It works quite OK in case you start the recording manually. But in case of automatic start from timer there will be no DVB-subtitels at all!!! Quote Link to comment
Guest Lars_MQ Posted December 28, 2005 Share Posted December 28, 2005 Manual and timed recordings are internally handled the same. So there is no reason why a timed recording should be different from a manual recording (remember I talk about the internal recording engine not the VRP). Quote Link to comment
Mikko-vaari Posted December 28, 2005 Author Share Posted December 28, 2005 (edited) Manual and timed recordings are internally handled the same. So there is no reason why a timed recording should be different from a manual recording (remember I talk about the internal recording engine not the VRP). <{POST_SNAPBACK}> Yes, that's why I'm wondering and that's why I believe there is a bug. I'm not using any plugins. To be exact, I tried to record in .TS-format. Now I made more studies: If you start - manually or timed - the recording before the program has started, DVBV don't find DVB-subtitels. Edited December 28, 2005 by Mikko-vaari Quote Link to comment
emmel Posted December 28, 2005 Share Posted December 28, 2005 I think the original question was about "dynamic subtitles": If the recording starts before a subtitled program begins, and there was no subpict pid present before, the subs might be missing from the recording (pmt changes after the recording has started). Quote Link to comment
Guest Lars_MQ Posted December 28, 2005 Share Posted December 28, 2005 This could be a explanation. the PMT is only examined at the starting of the recording. And all found matching PIDs are added to the recording. A change while the recording is running is not possible. But this should be quite easy to test: simply programm a timer for a running programm with subtitles. [edit]christian told me, even if there are no subtitles, they should transmit the subtitles pids. it's written somewhere in the specifications. So the above text could be pure nonsense. Sorry [/edit] Quote Link to comment
IRa Posted December 28, 2005 Share Posted December 28, 2005 This could be a explanation. the PMT is only examined at the starting of the recording. And all found matching PIDs are added to the recording. A change while the recording is running is not possible. That is the case, YLE in Finland is sending dynamic subtitles and as far as I know there is no PID before the program with subtitlkes starts. So they can send differnt subtitles (languages) debending on the program. All my scheduled recordings with 3.2.6 are now without subs becauserecordings starts a little before the program starts. Unfortenately the improvment in 3.2.6 does not help much in reality. So after a short joy I must go back again to use videorecorder plugin and "qhost" channels with fixed subtitle PID replacing audio PID because I don't want miss the beginning of the program. Quote Link to comment
emmel Posted December 28, 2005 Share Posted December 28, 2005 This could be a explanation. the PMT is only examined at the starting of the recording. And all found matching PIDs are added to the recording. A change while the recording is running is not possible. But this should be quite easy to test: simply programm a timer for a running programm with subtitles. [edit]christian told me, even if there are no subtitles, they should transmit the subtitles pids. it's written somewhere in the specifications. So the above text could be pure nonsense. Sorry [/edit] <{POST_SNAPBACK}> Just checked: Recording with ongoing dvb-subs is ok. Also checked the pmt of another channel that uses dvb-subs: no subtitle pid present at the moment (the provider is YLE, the Finnish national broadcasting company - famous for doing things as they wish...). Quote Link to comment
Guest Lars_MQ Posted December 28, 2005 Share Posted December 28, 2005 This is getting quite difficult now I'll have to ask Christian, if there is something we can do about it. Quote Link to comment
IRa Posted December 28, 2005 Share Posted December 28, 2005 This is getting quite difficult now I'll have to ask Christian, if there is something we can do about it. <{POST_SNAPBACK}> What if the wanted sub PID would be added already to channel list and program would use that. Quote Link to comment
Derrick Posted December 28, 2005 Share Posted December 28, 2005 [edit]christian told me, even if there are no subtitles, they should transmit the subtitles pids. it's written somewhere in the specifications. So the above text could be pure nonsense. Sorry [/edit] ..seems to be a selfmade rule by the head programmer The PMT is dynamic and the number and/or types of elementary streams can change at any time (new PMT_version). Quote Link to comment
emmel Posted December 28, 2005 Share Posted December 28, 2005 Heres the content of two subsequent pmts, when the change happens: Before: -------------------------------------------------------- PMT on PID 256 contains the following information: program_number = 17 PCR_PID = 128(clock) elementary_PID = 512(video) elementary_PID = 650(audio) elementary_PID = 2321(PES packet)[teletext] fin startpage 100 elementary_PID = 3120(section) elementary_PID = 3110(ISO/IEC 13816-6 (type B )) elementary_PID = 3111(ISO/IEC 13816-6 (type B )) -------------------------------------------------------- After: -------------------------------------------------------- PMT on PID 256 contains the following information: program_number = 17 PCR_PID = 128(clock) elementary_PID = 512(video) elementary_PID = 650(audio) elementary_PID = 2321(PES packet)[teletext] fin startpage 100 elementary_PID = 1028(PES packet)[DVB subtitle: swe] elementary_PID = 3120(section) elementary_PID = 3110(ISO/IEC 13816-6 (type B )) elementary_PID = 3111(ISO/IEC 13816-6 (type B )) -------------------------------------------------------- Quote Link to comment
jouko999 Posted January 1, 2006 Share Posted January 1, 2006 Finnish YLE seems to be the first broadcasting company using dynamic dvb subtitling, but they follow the standards - it is not their own invention. This topic has been handled in many other forums lately, the producers of set-top boxes have already solved the problem, and so has Nebula. Let's be patient, I guess subtitles are working correctly in the upcoming major version. Until that it seems that we Finnish users have to use Videorecorder plugin and 'ghost' channels in the channellist. Here a list of some transmitted PIDS in Finland, and teletext subtitles pages as well: YLETV1 YLETV2 YLEFST YLE24 YLETeema suomi 1027 2027 3027 5027 4027 ruotsi 1028 2028 3028 5028 4028 englanti 1029 2029 3029 5029 4029 ranska 1030 2030 3030 5030 4030 espanja 1031 2031 3031 5031 4031 italia 1032 2032 3032 5032 4032 venäjä 1033 2033 3033 5033 4033 norja 1034 2034 3034 5034 4034 tanska 1035 2035 3035 5035 4035 islanti 1036 2036 3036 5036 4036 saksa 1037 2037 3037 5037 4037 portugali 1038 2038 3038 5038 4038 saame 1039 2039 3039 5039 4039 viro 1040 2040 3040 5040 4040 tekstitv-tekstitykset: 450 infosivu 451 TV1 suomi 452 TV2 suomi 453 YLE Teema suomi 454 YLE24 suomi 455 TV1 ruotsi 456 TV2 ruotsi 457 YLE Teema ruotsi 458 YLE24 ruotsi 459 Muut kielet 460 englanti 461 saksa 462 ranska 463 italia 464 espanja 465 portugali 466 viro pidejä pmt256 (17) yle1 vid 512 0x200 aud 650 0x28a 2. kieli 652 0x28c dvb 1027-1040 0x403-0x410 (33) yle2 vid 513 0x201 aud 660 0x294 dvb 2027-2040 (81) fst 514 0x202 670 0x29e 3027-3040 0xbd3-0xbe0 (129) yle24 515 0x203 680-683 0x2a8-2ab 4027-4040 (145) yleteema 516 0x204 690 0x2b2 5027-5040 kaikissa tekstitv PID 2321 0x911 radiot: (4369) Peili 692 0x2b4 (4385) Q 653 0x28d (4401) Yle Klassinen 662 0x296 (4417) FSR 663 0x297 (4433) Mondo 673 0x2a1 (4481) X3M 685 0x2ad Quote Link to comment
Mikko-vaari Posted January 3, 2006 Author Share Posted January 3, 2006 Until that it seems that we Finnish users have to use Videorecorder plugin and 'ghost' channels in the channellist. The ghostchannels and VR Plugin are not any more needed using 3.2.6version!! Quote Link to comment
jouko999 Posted January 3, 2006 Share Posted January 3, 2006 Until that it seems that we Finnish users have to use Videorecorder plugin and 'ghost' channels in the channellist. The ghostchannels and VR Plugin are not any more needed using 3.2.6version!! <{POST_SNAPBACK}> But 3.26 misses the dvb subtitles if recording is started before the subtitles pid has appeared. With the ghost channels it is possible to 'force' the recording of the subtitles pid. Quote Link to comment
Mikko-vaari Posted January 4, 2006 Author Share Posted January 4, 2006 (edited) Until that it seems that we Finnish users have to use Videorecorder plugin and 'ghost' channels in the channellist. The ghostchannels and VR Plugin are not any more needed using 3.2.6version!! <{POST_SNAPBACK}> But 3.26 misses the dvb subtitles if recording is started before the subtitles pid has appeared. With the ghost channels it is possible to 'force' the recording of the subtitles pid. <{POST_SNAPBACK}> Ahaa - I didn't know that! I always thought that it's only for teletxt. Thanks, I'll try DVB-text. Edited January 4, 2006 by Mikko-vaari Quote Link to comment
