JKKIN Posted January 1, 2006 Share Posted January 1, 2006 (edited) Dvb subtitles don`t show anymore .They did show with the previous version (3.2..5). I uninstalled the old version before I installed the new one ,which propably I shouldn`t have done. I have done several reinstalls ,checked and rechecked the configuration but the subtitles won`t show up. Otherwise the program works perfectly here`s some info about my system Windows XPpro sp2 Athlon 2400+ 512 ram Matrox Millennium G400 DualHeadMax(driver 5.93.9.0) Hauppauge Nova-T Pci (newer)(driver 2.106.23151.0) DVBViewer 3.2.6.80 setup.xmlMPEGDecoder.txt Edited January 6, 2006 by JKKIN Quote Link to comment
emmel Posted January 1, 2006 Share Posted January 1, 2006 3.2.6.80 also here, and the dvb-subs work fine. Quote Link to comment
jouko999 Posted January 1, 2006 Share Posted January 1, 2006 Be sure to record in .ts format to get subtitles recorded. Seems the software does not follow the dvb subtitles PID dynamically. If the recording starts when no dvb subtitles are present there are no subtitles recorded. If the recording is started during a subtitled program everything works fine. This is a problem at least here in Finland. A note to the development team: Finnish Broadcasting company YLE has announced that they transmit teletext subtitles only temporarily, for those countryside customers whose old satellite box does not support dvb subtitles. So this is just a workaround until YLE has a full coverage in their terrestrial network. Quote Link to comment
JKKIN Posted January 2, 2006 Author Share Posted January 2, 2006 The thing is I don`t see them at all.Recording them is another question. Quote Link to comment
boehler Posted January 2, 2006 Share Posted January 2, 2006 The thing is I don`t see them at all.Recording them is another question. <{POST_SNAPBACK}> I just tested this with the actual version 3.2.6.80 and it works fine (channel "Sat1" on DVB-T). Are you sure that your channel contains subtitles? Did you already check the videotext reception? Quote Link to comment
JKKIN Posted January 2, 2006 Author Share Posted January 2, 2006 The texts should be there .Question is about Yle Finnland. Where could I get the version 3.2.5 ? Subtitles with It worked but I don`t have the setup package anymore. Quote Link to comment
Derrick Posted January 2, 2006 Share Posted January 2, 2006 I just tested this with the actual version 3.2.6.80 and it works fine (channel "Sat1" on DVB-T). Are you sure that your channel contains subtitles? Did you already check the videotext reception? He's interested in DVB_subtitling and not in german teletext subtitles Quote Link to comment
emmel Posted January 2, 2006 Share Posted January 2, 2006 (edited) The texts should be there .Question is about Yle Finnland. Hi, I just compared the ini -file you posted to my setup. Seems that your ini -file is for some older version of DVBViewer? Don't know if it matters, but i have some additional sub-related entries in my ini-file. emmel ps. For the DVBViewer crew: I guess the standard you refer to in the dialog box Settings->Options->EPG/Teletext->Subtitles should be 300 743? Yes, I know, its not critical... Edited January 2, 2006 by emmel Quote Link to comment
JKKIN Posted January 5, 2006 Author Share Posted January 5, 2006 Did complete reinstal of everything (starting with format c:). Only other installed programs are firewall (Kerio) , antivirus (Avg), Windows updates and latest DX. Still no DVB subtitles. MPEGDecoder.txt setup.xml Quote Link to comment
JKKIN Posted January 9, 2006 Author Share Posted January 9, 2006 (edited) Here is a channel info page of a channel that sends DVB subtitles .If I have understood it right there should be a PID for them. Could you tell me if this seems right? Are there all the PIDS there should be? Edited January 14, 2006 by JKKIN Quote Link to comment
jouko999 Posted January 9, 2006 Share Posted January 9, 2006 Here is a channel info page of a channel that sends DVB subtitles .If I have understood it right there should be a PID for them. Could you tell me if this seems right? Is there all the PIDS there should be? <{POST_SNAPBACK}> When choosing DVB subtitles be sure that also language is selected - sometimes the field shows just empty and when clicking it you can choose 'Finnish'. This must be done during a program which contains subtitles. Are you sure you don't try viewing Teletext subtitles? Just now they don't work because YLE has changed something in the transmission. Quote Link to comment
JKKIN Posted January 9, 2006 Author Share Posted January 9, 2006 I`ve selected DVB subtitles and the language selection is also correct. Quote Link to comment
JKKIN Posted January 30, 2006 Author Share Posted January 30, 2006 DVB subtitles work again, with this new Beta. Excellent! Quote Link to comment
Guest Lars_MQ Posted January 30, 2006 Share Posted January 30, 2006 Yes the subtitle part is now working. for all changes regarding subtitles have a look at the changelog in the readme.pdf. Quote Link to comment
