HELP! Nova-S with latest Technotrend BDA Drivers
markymark
Hi All,
I was hoping to get DiSEqC support with the new Technotrend BDA drivers (from 12.12.2005) ... instead tuning doesnt work anymore at all. With earlier drivers, I was able to receive from the first LNB.
Any suggestions?
Thanks for your help ...
PS: The Technotrend BDA software works flawlessly :)
As far as I understood Griga you simply have to reselect the Hardware in DVBViewer GE because the Device ID changed. In TransEdit.ini it should (? at least without DiSEqC it's working now ?) be:
ID.0=@device:pnp:\\?\stream#hcw88bda.m92xx#5&12858f4f&1&1#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{91b0cc87-9905-4d65-a0d1-5861c6f22cbf}
And maybe you have:
ID.0=@device:pnp:\\?\stream#hcw88bda.m92xx#5&12858f4f&0&1#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{91b0cc87-9905-4d65-a0d1-5861c6f22cbf}
Jochen
<Edit>Sorry, this is for Nova-S Plus only, not Nova-S Budget Line.</Edit>
Edited by JMS
And maybe you have:
Jochen
I checked, but it doesn seem to be the problem. I also tried all the different tuning spaces. Also checked in both DVBViewer and GE. TransEdit also doesnt find anything :)
