lout Posted January 7, 2006 Posted January 7, 2006 Hi i use xp sp2 and remote mce 2005 i put mce2005 remote plugin in to plugins folder thnen i select in option but nothing change remote work like without plugin no working buttons (pause , play .....)plz any help Quote
daffy Posted January 7, 2006 Posted January 7, 2006 i use xp sp2 and remote mce 2005 i put mce2005 remote plugin in to plugins folder thnen i select in option but nothing change remote work like without plugin no working buttons (pause , play .....) a) You need to enable the input plugin in the Input -> Inputplugins section of the Options dialog You need to teach DVBViewer what to do in response to remote control activity - see the "Learn" button? (Input section of the Options dialog) FWIW, the MCE 2005 remote control works just marvelously over here. Quote
gibman Posted January 9, 2006 Posted January 9, 2006 It's a shame that we can't have context dependent button events. What I mean is. Once you have assigned the MCE "OK" button to the OSD-ok function, then you can't have the OK button act as anything other than that. Ex. when I did my Uice DVBViewer programming (with ATI remote wonder), I did this so I could have various functions on the same button depending on in which context DVBViewer currently is in. My uice'd ATI rem. wonder "OK" button has 2 functions: 1) In normal channel display context mode my OK button triggers the EPG-OSD menu. 2) In OSD context mode my OK button triggers the OSD-select action. This way you don't run out of buttons too soon. And it also has the extra bonus of being a bit more wife friendly I think. I know this part is a feature request. Maybe it would be wise to take full use of the groups in the input options dialogue. Each group has it's own keys where I don't get the "reassign the event" message when using the same key but in a different group. Or maybe assign a context to each group. ex. MyOSDGroup assigned to OSD context. OSD ok keyb. spacebar MyChannelsGroup assigned to Channel context EPG menu keyb. spacebar I know this gives more sense when talking about a limited remote control. The keyboard has a lot of keys to choose from. /Elo Quote
klausb Posted January 9, 2006 Posted January 9, 2006 It's a shame that we can't have context dependent button events.... <{POST_SNAPBACK}> I agree. It's probably hard to configure, but very helpful. I got used to the handling of the Neutrino/Linux firmware in my DBox II. There I have a lot of context dependent button events. E.g. pressing ? once shows a mini EPG (i.e. name of the movie and running time). While the mini EPG is showing (it disappears after a while) pressing ? a second time show the full EPG of the movie. I would be happy, if this would be possible with some COM scripting. Maybe Lars could give us some advice. klaus. Quote
