Yakumo QuickStick DVB-T
sCrew
Hi, can anybody help me with installing/setting up the DVBViewer?
Yesterday i've bought DVBViewer and installed Yakumo QuickStick with BDA drivers, which should work with the DVBViewer Pro. I can see any HW settings or an option to switch to DVB-T.
Any idea?
Link to comment
DVBViewer GE works, but PRO doesn't. ;)
Should be: DVBViewer GE works ;) but Pro doesn't.
Try to use TransEdit for scanning and export the results to DVBViewer Pro (rightclick the scan results -> select all -> rightclick again -> send to DVBViewer, or export as INI file and import in the DVBViewer's channellist window).
Link to comment
Solved ;)
I had to restart PC, change the DirectX settings in Options menu and then...
IT WORKS!!!
I've searched manual and this forum without any result, so this should be improved in the manual/help. Maybe for some noobs (like i am) some wizard will be appreciated.
Link to comment
