lemanruss Posted February 2, 2006 Share Posted February 2, 2006 Hi there. I've just tried to re-install DVBViewer, and configure it to work properly 3 days ago, with the latest version. No problems has to be reported except one thing. I'm not able to edit channels. There was, before, (maybe with the Technisat version of DVBViewer) a very usefull file named, Channels.dat. Unfortunately I didn't manage to find it on my hard drive with this version (3.2.6.80). So, I wonder how could I edit/sort/delete/arange/and so on, without using DVBViewer's built in editing options (I think that those are very inconvenients). And I also wonder where all this kind of stuff is now stored. I've even search the registry. Thanks for your replies. Quote Link to comment
Guest Lars_MQ Posted February 2, 2006 Share Posted February 2, 2006 enable searching in systemsdir then it will most likely find it in dokuments and settings\all users\applicationdata\DVBViewer pro or dokuments and settings\[username]\applicationdata\DVBViewer pro I'm not too sure about the english names of the folders but the general direction should help you a little bit Quote Link to comment
lemanruss Posted February 2, 2006 Author Share Posted February 2, 2006 (edited) enable searching in systemsdir then it will most likely find it in dokuments and settings\all users\applicationdata\DVBViewer pro or dokuments and settings\[username]\applicationdata\DVBViewer pro I'm not too sure about the english names of the folders but the general direction should help you a little bit <{POST_SNAPBACK}> Yeah !!!!! Thank you very much, you are the king ^^ Edited February 2, 2006 by lemanruss Quote Link to comment
