internet Posted February 9, 2006 Posted February 9, 2006 I am thinking of purchasing DVBViewer Pro 3.x, before purchasing the software can someone tell me whether DVBViewer Pro 3.x works with Freecom DVB-T USB Receiver? Thanks in advance! Quote
ardeee Posted February 12, 2006 Posted February 12, 2006 Hi, Works perfectly for me in the UK. Use the TransEdit Scanner & Editor in the downloads section to scan for terrestial channels. Also remember to change your DirectX settings to point to the correct DVB hardware. -- Ricky Dee My Blog Quote
internet Posted February 12, 2006 Author Posted February 12, 2006 Thanks Ricky, i downloaded Transedit_MMC_Demo and tested successfully with my Freecom DVB-T USB Receiver! One more question if i may - what do you think of DVBViewer compare with other products? Quote
ardeee Posted February 13, 2006 Posted February 13, 2006 (edited) Hi, I wrote a post about other software that I tried on my blog. Might be of some use. DVBViewer Software -- Ricky Dee My Blog Edited February 13, 2006 by ardeee Quote
mpatrick Posted April 15, 2006 Posted April 15, 2006 Hi, I would like to get my Freecom DVB-T stick to work with the DVB software. When you say 'change your DirectX settings to point to the correct DVB hardware' - what do you mean?? I would be grateful if you would post some instructions on how to get my Freecom stick to work with DVB software, as I see you have done. Thanks for your help Quote
Guest Lars_MQ Posted April 15, 2006 Posted April 15, 2006 Which version of the DVBViewer are you talking about? Quote
mpatrick Posted April 16, 2006 Posted April 16, 2006 I downloaded the Technisat edition from the DB viewer website, so that I could try this out first before I buy. However when I try to install this it says it cannot recognise the hardware? Will this work with my freecom DVB-T stick, or do I have to buy the full version and will this also work? Thanks for your help Regards Michael Quote
Guest Lars_MQ Posted April 16, 2006 Posted April 16, 2006 The TECHNISAT Editon only works with TECHNISAT cards (sky/cable/airstar). Quote
mpatrick Posted April 29, 2006 Posted April 29, 2006 HI I purchased the DVB proffesional version and installed this successfully. However I cannot get this to work with my Freecom DVB-T stick. I installed the Yakumo BDA drivers previously which are reporting as the device was successfully installed. I changed the Direct X settings within the software to digital TV reciever using DVB stick. When I scan for terrestrial channels it does not pick any up?? I also downloaded the transedit MMC software but could not make any sense of this. Please help as the previous entries are all saying that they have this working with the Freecom stick. Thanks for your help Michael Patrick Quote
no prece ja Posted May 1, 2006 Posted May 1, 2006 HI I purchased the DVB proffesional version and installed this successfully. However I cannot get this to work with my Freecom DVB-T stick. I installed the Yakumo BDA drivers previously which are reporting as the device was successfully installed. I changed the Direct X settings within the software to digital TV reciever using DVB stick. When I scan for terrestrial channels it does not pick any up?? I also downloaded the transedit MMC software but could not make any sense of this. Please help as the previous entries are all saying that they have this working with the Freecom stick. Thanks for your help Michael Patrick <{POST_SNAPBACK}> Start the DVBViewer, then click on channel menu - in this menu click "Channelist", in Channelist click on tab "Channel scan", there choose "Terrestrial (EUR)" in "Root" and click "Scan" - thats all Quote
mpatrick Posted May 2, 2006 Posted May 2, 2006 Yes I did that and when I press scan it does not pick up any channels Michael Quote
