Bermar Posted February 12, 2006 Posted February 12, 2006 Any help / suggestions to get satellites (Astra 19.2°, Hotbird 13°, Astra 28°) DVBViewer Pro installed and with channel scan program freezes after a number of channels detected from Astra (several trials done). With Transedit 2.5 all 1356 channels from Astra 19.2 found and DVBViewer displays/records great, but no channels for Hotbird + Asra 28. I have tried all combinations of Pos A/Opt B etc. DVBViewer Beta 3.4.9.2 installed. Scanning channels for Astra 19.2 works with channel scan. No channels for Hotbird & ASra 28. After some time a serious crash occurred and PC started completely from scratch and needed 30 minutes for recovery from serious problem. With PowerCinema (comes with the PC) I can get the channels from the other satellites with the 4x1 Diseqc switch. I like DVBViewer very much but I need some ideas/sugestions to get around with the diseqc switch to get also Hotbird and Astra 28. I have scanned al the forums and internet but found no solution till so far. Has anybody some ideas/suggestions ? Configuration: Windows XP Home SP2 Pentium D CPU 3.00 GHz PC: Medion MD8800 SAA 7131 Hybrid Capture Device 1&2 NVIDIA GeForce 6700 XL DVBViewer Pro 3.2.6.80 Diseqc 1.2 switch 4x1 setup.xml DVBViewer.log MPEGDecoder.txt Quote
Guest Lars_MQ Posted February 12, 2006 Posted February 12, 2006 After some time a serious crash occurred and PC started completely from scratch and needed 30 minutes for recovery from serious problem. An application can not cause such a crash, normaly a driver is only able to do such thing. Next thing: Microsoft unfortunately forgot such "stupid" and "unnessary" things like DiseqC and CI in their BDA definitions. So for each card(type) there has to be individual code to access DiseqC. Currently Twinhan, NovaS, NovaSplus and firesatdtv BDA work with diseqC. We try to integrate the stuff, if we can get our hands on the api/sdk of the driver developers (each company solves this problem of course different, otherwise it would be too easy ). Another thing: try setting in options / directX the video and audiodecoder to cyberlink sp instead to auto, the dscaler codec is quite crappy. I move the thread cause it's no bug. Quote
Bermar Posted February 14, 2006 Author Posted February 14, 2006 After some time a serious crash occurred and PC started completely from scratch and needed 30 minutes for recovery from serious problem. An application can not cause such a crash, normaly a driver is only able to do such thing. Next thing: Microsoft unfortunately forgot such "stupid" and "unnessary" things like DiseqC and CI in their BDA definitions. So for each card(type) there has to be individual code to access DiseqC. Currently Twinhan, NovaS, NovaSplus and firesatdtv BDA work with diseqC. We try to integrate the stuff, if we can get our hands on the api/sdk of the driver developers (each company solves this problem of course different, otherwise it would be too easy ). Another thing: try setting in options / directX the video and audiodecoder to cyberlink sp instead to auto, the dscaler codec is quite crappy. I move the thread cause it's no bug. <{POST_SNAPBACK}> Thanks for the reply and the tip for DirectX We try to integrate the stuff, if we can get our hands on the api/sdk of the driver developers (each company solves this problem of course different, otherwise it would be too easy ).. If I can help with anything for this integration, please let me know. I am very interested. Quote
Griga Posted February 14, 2006 Posted February 14, 2006 There is something you may try (without any promise for success). SAA 7131 is a Philips chip. There is code in TransEdit 2.5 that sets DiSEqC for TechnoTrend based cards, and in some sample code I saw a remark saying that this kind of DiSEqC function call applies to Philips chipsets. For activating this code you have to edit your TransEdit.ini file with a text editor. First find out where it is is, since TransEdit stores it according to the user mode that you have selected when installing DVBViewer Pro. More about the user mode here. In the TransEdit.ini, search the [Hardware] section, and within this section, the entry vendor.0=0 Change it to vendor.0=3 that tells TransEdit that your SAA 7131 is a TechnoTrend based device. Save the changed file, launch TransEdit and try... it will now apply the according DiSEqC code. It *may* work, if the driver supports DiSEqC in the same way as the TechnoTrend drivers do. However, it may crash or do nothing as well... just a gamble. Quote
Bermar Posted February 14, 2006 Author Posted February 14, 2006 There is something you may try (without any promise for success). SAA 7131 is a Philips chip. There is code in TransEdit 2.5 that sets DiSEqC for TechnoTrend based cards, and in some sample code I saw a remark saying that this kind of DiSEqC function call applies to Philips chipsets. For activating this code you have to edit your TransEdit.ini file with a text editor. First find out where it is is, since TransEdit stores it according to the user mode that you have selected when installing DVBViewer Pro. More about the user mode here. In the TransEdit.ini, search the [Hardware] section, and within this section, the entry vendor.0=0 Change it to vendor.0=3 that tells TransEdit that your SAA 7131 is a TechnoTrend based device. Save the changed file, launch TransEdit and try... it will now apply the according DiSEqC code. It *may* work, if the driver supports DiSEqC in the same way as the TechnoTrend drivers do. However, it may crash or do nothing as well... just a gamble. <{POST_SNAPBACK}> Tried the proposed change vendor.0=0 to vendor.0=3 (in the right usermode), but no channels for hotbird or astra and ... no crash. I see also vendor.1, vendor.2 and vendor.3 Those I haven't changed. Is that correct ? Anyway, thanks for helping to get a solution. Quote
Griga Posted February 14, 2006 Posted February 14, 2006 I see also vendor.1, vendor.2 and vendor.3 Those I haven't changed. Is that correct ? I see - one of those Medion multiple tuner devices. 2 x DVB-S, 2 x DVB-T, I suppose - you didn't tell us. Ok, then try again, and change all vendor.x entries with TunerType.x=1 which means DVB-S. Perhaps index 0 is related to a DVB-T tuner... Quote
Bermar Posted February 15, 2006 Author Posted February 15, 2006 I see also vendor.1, vendor.2 and vendor.3 Those I haven't changed. Is that correct ? I see - one of those Medion multiple tuner devices. 2 x DVB-S, 2 x DVB-T, I suppose - you didn't tell us. Ok, then try again, and change all vendor.x entries with TunerType.x=1 which means DVB-S. Perhaps index 0 is related to a DVB-T tuner... <{POST_SNAPBACK}> Any suggestions ? DVBViewer plays channels Astra. When I start scanning with DVBViewer Pro, program finds channels but after some period scanning aborts. Had the problem before and uses Transedit. Transedit works fine and all 1356 channels found and import in DVBViewer. DVBViewer plays nice the channels of Astra. After the discussions about Diseqc (see thread), Transedit does not find any channels (Astra, Hotbird, Astra 2). DVBViewer finds channels for Astra but stops somewhere in the scan. Have tried also DVBViewer Beta. DVBViewer Beta scanning finds only 264 channels for Astra. Plays channels for Astra. Transedit in Beta dir does not find any channels Astra. Attached my Transedit.ini from DVBViewer Pro folder. Should I reinstall DVBViewer Pro / remove DVBViewer Beta or ...... ? Detected Devices: 713x BDA DVBT Tuner 713x BDA DVBS Tuner 713x BDA DVBT Tuner 713x BDA DVBS Tuner Any help will be much appreciated. TransEdit.ini Quote
Griga Posted February 15, 2006 Posted February 15, 2006 Sorry, for some odd reason I can't download the ini file. Please attach it zipped. After the discussions about Diseqc (see thread), Transedit does not find any channels After applying the vendor.x = 3? And what about setting it back to 0? What kind of equipment do you use? Quattro LNB plus switch? If the DVB device won't work properly after the things you've tried, even not after rebooting, it has to be reset. Switch your PC off and diconnect it from the power supply for some seconds. Or go to the Windows device manager and deactivate / re-activate the device. Quote
Bermar Posted February 16, 2006 Author Posted February 16, 2006 Sorry, for some odd reason I can't download the ini file. Please attach it zipped. After the discussions about Diseqc (see thread), Transedit does not find any channels After applying the vendor.x = 3? And what about setting it back to 0? What kind of equipment do you use? Quattro LNB plus switch? If the DVB device won't work properly after the things you've tried, even not after rebooting, it has to be reset. Switch your PC off and diconnect it from the power supply for some seconds. Or go to the Windows device manager and deactivate / re-activate the device. <{POST_SNAPBACK}> Life is nice. This morning Transedit scans channels for Astra (1351 Channels). Maybe good reset of the device (one night !!) and in hardware of Transedit first 713x BDA DVBT Tuner stood on Satellite. I changed that to Terrestrial and it works for Astra. Not for Hotbird with Transini attached. Also with another reset of PC. I have only for TunerType.1=1 Vendor.1=0 changed to 3. I use 3 LNB's with Diseqc 1.2 4x1 switch. TransEditini.zip Quote
Bermar Posted February 25, 2006 Author Posted February 25, 2006 Sorry, for some odd reason I can't download the ini file. Please attach it zipped. After the discussions about Diseqc (see thread), Transedit does not find any channels After applying the vendor.x = 3? And what about setting it back to 0? What kind of equipment do you use? Quattro LNB plus switch? If the DVB device won't work properly after the things you've tried, even not after rebooting, it has to be reset. Switch your PC off and diconnect it from the power supply for some seconds. Or go to the Windows device manager and deactivate / re-activate the device. <{POST_SNAPBACK}> Life is nice. This morning Transedit scans channels for Astra (1351 Channels). Maybe good reset of the device (one night !!) and in hardware of Transedit first 713x BDA DVBT Tuner stood on Satellite. I changed that to Terrestrial and it works for Astra. Not for Hotbird with Transini attached. Also with another reset of PC. I have only for TunerType.1=1 Vendor.1=0 changed to 3. I use 3 LNB's with Diseqc 1.2 4x1 switch. <{POST_SNAPBACK}> Is there any workaround to use 3 LNB's with a Diseqc 4x1 switch with DVBiewer + MD8800 (SAA7131)? Is there anybody whos knows a Diseqc generator to switch separate from the PC the switch to another satellite or are there other ideas ? Quote
Derrick Posted February 25, 2006 Posted February 25, 2006 Is there any workaround to use 3 LNB's with a Diseqc 4x1 switch with DVBiewer + MD8800 (SAA7131)? no, not to my knowledge Is there anybody whos knows a Diseqc generator to switch separate from the PC the switch to another satellite or are there other ideas ? theoretically possible but you have to block any control signals from the MD otherwise the card will reset the switch to astra, because with each channel change a hardwired astra_diseqc_command will be sent. Quote
Griga Posted February 25, 2006 Posted February 25, 2006 If I knew which kind of DiSEqC interface with which parameters the MD provides, I would code it. But I have no idea where to get the information from. You can try to contact Medion and ask for it, resp. ask who has to be asked for the specifications... Quote
Bermar Posted February 25, 2006 Author Posted February 25, 2006 If I knew which kind of DiSEqC interface with which parameters the MD provides, I would code it. But I have no idea where to get the information from. You can try to contact Medion and ask for it, resp. ask who has to be asked for the specifications... <{POST_SNAPBACK}> Thanks. I will ask Medion but that takes some time and I am not sure if they are willing to coorporate. Nevertheless I will try and I let you know the outcome. Quote
mittern8 Posted February 25, 2006 Posted February 25, 2006 I'm afraid Medion won't be a great help. But as far as I've heared the maker of the card is CREATIX. Maybe it is a good idea to ask them for assistance too. Quote
Bermar Posted February 26, 2006 Author Posted February 26, 2006 I'm afraid Medion won't be a great help.But as far as I've heared the maker of the card is CREATIX. Maybe it is a good idea to ask them for assistance too. <{POST_SNAPBACK}> That's a better idea and even to ask Philips I can try. Thanks for the input. Quote
Bermar Posted March 3, 2006 Author Posted March 3, 2006 I'm afraid Medion won't be a great help.But as far as I've heared the maker of the card is CREATIX. Maybe it is a good idea to ask them for assistance too. <{POST_SNAPBACK}> That's a better idea and even to ask Philips I can try. Thanks for the input. <{POST_SNAPBACK}> I have contacted Creatix, the maker of the card and hopefully they are willing to help. Quote
Griga Posted March 3, 2006 Posted March 3, 2006 It's great that you are looking after it - thanks. You know, contacting all these companies takes a lot of time and keeps us away from coding - unfortunately we have no secretary.... Basically I need two things: - A method to detect the device, resp. to distinguish it from other devices. - A method to pass the DiSEqC setting to the BDA driver. ...and some sample code would be nice. Quote
Bermar Posted March 4, 2006 Author Posted March 4, 2006 It's great that you are looking after it - thanks. You know, contacting all these companies takes a lot of time and keeps us away from coding - unfortunately we have no secretary.... Basically I need two things: - A method to detect the device, resp. to distinguish it from other devices. - A method to pass the DiSEqC setting to the BDA driver. ...and some sample code would be nice. <{POST_SNAPBACK}> Griga, I am not so familiar with this kind of stuff, please some help. "To detect the device, resp. to distinguish it from others devices", which device do you mean, the CTX944 ? "A method to pass the DiSEqC setting to the BDA driver." you mean handing over the Diseqc instructions/controlling to the BDA driver ? " ...and some sample code would be nice. " interfacing example or other ? Quote
Guest Lars_MQ Posted March 4, 2006 Posted March 4, 2006 "To detect the device, resp. to distinguish it from others devices", which device do you mean, the CTX944 ? From the application point of view it's only a bda device. So you need a possibility to query "are you this and that device" in some way. Only if you can identify the device you can use the special handling routines for diseqc. Quote
Griga Posted March 4, 2006 Posted March 4, 2006 I am not so familiar with this kind of stuff I just wanted to tell you what is needed here in case the Creatix people ask for it. If they are able and willing to provide documentation, please send me a PM with a contact address or something like that... then I can take over. Quote
Bermar Posted March 6, 2006 Author Posted March 6, 2006 (edited) I am not so familiar with this kind of stuff I just wanted to tell you what is needed here in case the Creatix people ask for it. If they are able and willing to provide documentation, please send me a PM with a contact address or something like that... then I can take over. <{POST_SNAPBACK}> Edited March 7, 2006 by Bermar Quote
