Technotrend Budget C-1500 + CI
teemu_hil
Will CI work in this DVB-C card in the near future? myTheatre works fine with these so I believe it is possible to get these work (with Technotrend own drivers) in DVBViewer Pro.
Edited by teemu_hil
I am asking the same question, does the DVBViewer Pro support the WinTV-NOVA-CI in order to watch HD1 ?
Today I am using the MyTheatre SW.
Thanks,
Rittberg
Guest Lars_MQ
Yes the cards work with the BDA drivers, no the CI doesn't work for now.
Are you able to advise when the CI will work ( weeks, months ....)
Any plans for the new Technotrend S2-3200 HDTV-S2 (DVB S2 & CI)
Thanks,
Edited by Rittberg
Guest Lars_MQ
No plans for DVBS2 cards. If they support BDA no problem, otherwise we'll cross that brigde when they are actually able to deliver cards (my guess: summer or later :bye: ).
Hmm maybe I should suggest christian to seperate the DVB-S2 card app and sell it for 6 times the price of the DVBViewer (with a discount for DVBViewer owner - only 4 times the price). :)
when they are actually able to deliver cards (my guess: summer or later :) ).
DVB-S2 card - delivery at 15.3.06 according to DVBSHOP.
  • 1 month later...
Any news on this? Bought the card for purpose to be able to record the Canal+ programs i am not able to watch live. I think there will be quite many TT C-1500+CI owners in the near future, since there ain't many options for cable networks and the Twinhan cable card with CI is not widely available.
how about does this program support my card?
Technotrend DVB-C Budget C1500 (CI)
program doesn't find my card in setting. can I define it somehow manually?
