cocksy_boy Posted March 10, 2006 Posted March 10, 2006 Hi There All, Just a quick question - is there any way to upmix stereo broaqdcasts to 5.1? Basically, I'm using DVBViewer Pro with my Nova-T PCI in the UK where all the broadcasts are in stereo. Therefore, nothing comes out of my rear speakers - is there any way to upmix the sound to 5.1? I tried just selecting the AC3 filter in the DirectX options, but with no joy! Thanks for your help, Cocksy Quote
Griga Posted March 10, 2006 Posted March 10, 2006 I tried just selecting the AC3 filter in the DirectX options, but with no joy! Latest version? http://www.free-codecs.com/download/AC3_Filter.htm Go to View -> Filters and have a look what the AC3 Filter property page can do for you. Quote
hdv Posted March 10, 2006 Posted March 10, 2006 Hallo, it's from AC3 Filter 1.01a but i think it's the same in 1.02. you must select: Auto matrix Normalize matrix Voice control Expand stereo Bass redir look here for normal 5.1 Output: AC3 Output with AC3 Filter Quote
cocksy_boy Posted March 10, 2006 Author Posted March 10, 2006 Hi guys - thanks for that - I didn't relaise there was a newer version of the ac3 filter - I have only ever looked at his main site (whcih still only has version 0.70b!!). Got it woring - thanks very much for your quick responses! Cocksy Quote
pankov Posted March 16, 2006 Posted March 16, 2006 (edited) The upmixing engine in AC3Filter is not very good. If you really want to hear something good try the Circle Surround II plugin for Windows Media Player which can be used as DMO (similar to Direct Show filter). I find it much better than Dolby Prologic II. There is one problem though - it's not a MPEG audio decoder so you will have to build your own graph and add it after the audio decoder to make it work. ... or let's hope that hackbart will decide to add interface for configuring Audio Postprocessor as it's done for the video Edited March 16, 2006 by pankov Quote
bergh Posted March 16, 2006 Posted March 16, 2006 Hello ! If you can make Gold out of Led you can make 5.1 out of Stereo. O.K. a kind of upmix is possible, hence even the professional can not do magic. So if it is not necessary: Do not waste your time. Quote
pankov Posted March 16, 2006 Posted March 16, 2006 (edited) I agree that it's not perfect but the channel separation (vocals from the center, ambient sound from the surrounds, music from the main speakers, low freq from the Sub ) is so good that you can easily mistake it with a discrete 5.1 track. And for music it adds athmosphere with a little surround - not too much so you get distracted by the sound comming from the surrounds. You can also configre different settings for 3 modes - Movie; Music; Mono. So you can almost turn off the center speaker in Music mode so you keep the stereo sounding and only add some to the surrounds for better sound stage presentation That's how I see it (like it). Of course you may not like it - it's up to you. But if you haven't tried it ... really - do it. Edited March 17, 2006 by pankov Quote
bergh Posted March 17, 2006 Posted March 17, 2006 I agree that it's not perfect but the channel separation (vocals from the center, ambient sound from the surrounds, music from the main speakers, low freq from the Sub ) is so good that you can easily mistake it with a discrete 5.1 track.And for music it adds athmosphere with a little surround - not too much so you get distracted by the sound comming from the surrounds. You can also configre different settings for 3 modes - Movie; Music; Mono. So you can almost turn off the center speaker in Music mode so you keep the stereo sounding and only add some to the surrounds for better sound stage presentation That's how I see it (like it). Of course you may not like it - it's up to you. But if you haven't tried it ... really - do it. <{POST_SNAPBACK}> Hello ! Sorry any good Receiver with PLC II (or similar functions) does a better job in realtime. I hate this upmixes because you have glitsches and distortion very often. Quote
pankov Posted March 17, 2006 Posted March 17, 2006 (edited) Hello ! Sorry any good Receiver with PLC II (or similar functions) does a better job in realtime. I hate this upmixes because you have glitsches and distortion very often. <{POST_SNAPBACK}> if the guy is asking for upmixing he is probably not having a receiver that can upmix or he simply doesn't like the way it's upmixed. Personally I prefer CircleSurroundII than ProLogicII. The upmixing on the PC is also done in realtime with very little (a few ms) or none delay (because usually the video is synchronized to the audio). I don't know what you mean by glitches / distortion and what is "very often" to you but with probably thousands of hours of using CircleSurround I've never heard something that will ruin the very nice feeling about it. That's only how I see it. I'm not pushing anyone to use it - I'm just sharing my experience Edited March 17, 2006 by pankov Quote
bergh Posted March 17, 2006 Posted March 17, 2006 Hello ! I had gliches and distortion only with Software upmixed audio. The PLC II on my Denon Receiver works quite nice. And perhaps I should give Software upmixes another try ? Quote
pankov Posted March 17, 2006 Posted March 17, 2006 Hello ! I had gliches and distortion only with Software upmixed audio. The PLC II on my Denon Receiver works quite nice. And perhaps I should give Software upmixes another try ? <{POST_SNAPBACK}> It never hurts trying btw you've mentions "PLC II" twice. Is this Dolby Prologic II that you are talking about or it's something else? Quote
bergh Posted March 18, 2006 Posted March 18, 2006 Hello ! I had gliches and distortion only with Software upmixed audio. The PLC II on my Denon Receiver works quite nice. And perhaps I should give Software upmixes another try ? <{POST_SNAPBACK}> It never hurts trying btw you've mentions "PLC II" twice. Is this Dolby Prologic II that you are talking about or it's something else? <{POST_SNAPBACK}> Hello ! Thats how my Denon calls it. I think its something Like %channel Stereo , or Virtual Surround. The Receiver tries to "upmix" Stereo to 5.1. I must look in the Manual....... Quote
