gaz1874 Posted March 20, 2006 Share Posted March 20, 2006 will DVBViewer work with my kworld 100 dvb-t card with just a normal areial connection Quote Link to comment
nicc Posted March 20, 2006 Share Posted March 20, 2006 will DVBViewer work with my kworld 100 dvb-t card with just a normal areial connection <{POST_SNAPBACK}> the kworld vstream svb-t 100 is listed on http://www.DVBViewer.com/en/index.php?page=features as supported. It should if your aerial is upto it and you're in a decent reception area Quote Link to comment
gaz1874 Posted March 21, 2006 Author Share Posted March 21, 2006 will DVBViewer work with my kworld 100 dvb-t card with just a normal areial connection <{POST_SNAPBACK}> the kworld vstream svb-t 100 is listed on http://www.DVBViewer.com/en/index.php?page=features as supported. It should if your aerial is upto it and you're in a decent reception area <{POST_SNAPBACK}> it works great but i dont get setanta Quote Link to comment
nicc Posted March 22, 2006 Share Posted March 22, 2006 (edited) **A bug** ? works great but i dont get setanta <{POST_SNAPBACK}> Ah, yes a *bug* in DVBViewer, or more accurately a missing feature. Setanta is considered a Data channel*, and channel scans in DVBViewer only pick up Video & Audio channels. If you get hold of the TransEdit program from the members section you can scan for channels - do a complete scan if you like. In the scan ensure Data Services is selected in Filter 3. It will pick up the channel. (* I believe this is because the channel initially only comprises of an MHG screen - this is the information screen on the SetTopBox) Please note however DVBViewer does not display the MHEG screen (you'll get a blank screen). You can only see the video stream (that you can get by pressing Blue on a STB and entering your given code) by editing the video/audio PID's to the correct values. Edited March 22, 2006 by nicc Quote Link to comment
