gonzaloblanco1992 Posted March 27, 2006 Posted March 27, 2006 I have a few problems getting DVBViewer to stream through my wireless LAN. My system works almost faultlessly with ProgDVB (see my config below) but with DVBViewer can’t get anything at all, no sound, no picture. Yes, I bought the DVBViewer because I thought would be easier and better, but no much fun so far. Indeed DVBViewer works fine on the desktop on its own, but as soon as I open the server option in the desktop, the program freezes and stops. I wanted to stream to the laptop but this has been so far impossible; I think by now have tested all combinations suggested in the instructions. If I open the DVBserver only (without the viewer) my laptop shows up in the clients panel, changing channels in the laptop will also trigger a list of actions in the “Debug” panel in DVBserver. I have also tried each one of the TTL options, closing and opening the program or even restarting both the server and client computers with same frustrating result. If anyone please can provide some extra tips. My configuration: AMD Athlon™XP 2100+, 1.72 GHz, 512 Mb of RAM, running Windos XP professional SP2. TechniSat DVB-PC TV Star PCI 2, DVBViewer pro Thanks! Gonz Quote
Guest Lars_MQ Posted March 28, 2006 Posted March 28, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
gonzaloblanco1992 Posted March 28, 2006 Author Posted March 28, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 <{POST_SNAPBACK}> The log files? I have attached them (from client), cant acces the ones from server right now. My version: 3.2.6.80 DVBViewer.log setup.xml Quote
gonzaloblanco1992 Posted March 28, 2006 Author Posted March 28, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 <{POST_SNAPBACK}> The log files? I have attached them (from client), cant acces the ones from server right now. My version: 3.2.6.80 <{POST_SNAPBACK}> What else do you need? Could you please be a bit more explicit? I can’t see anything else to provide in that link. Am I the only one struggling to get this properly set up? Hopefully some of you will have some clues...? Quote
Guest Oliver Posted March 28, 2006 Posted March 28, 2006 You must attach the generated support.zip. Quote
gonzaloblanco1992 Posted March 28, 2006 Author Posted March 28, 2006 You must attach the generated support.zip. <{POST_SNAPBACK}> Thanks for the reply this one is the support.zip from the client support.zip Quote
gonzaloblanco1992 Posted March 28, 2006 Author Posted March 28, 2006 You must attach the generated support.zip. <{POST_SNAPBACK}> Thanks for the reply this one is the support.zip from the client <{POST_SNAPBACK}> And this one from the desktop server computer. Hope it helps support.zip Quote
gonzaloblanco1992 Posted March 29, 2006 Author Posted March 29, 2006 Does anyone know if there is any other forum where I may find some support regarding DVBViewer client/server problems? Quote
gonzaloblanco1992 Posted March 31, 2006 Author Posted March 31, 2006 Given the overwhelming response, here is a good tip for Oliver, Lars and the rest of DVBViewer users: if you have any problems with the server/client feature of DVBViewer do the following: uninstall the full application and bin it, then install ProgDVB. ProgDVB is more widely used, easier to set up and, in contrast to DVBViewer, there are forums where you can actually get support! So long folks… Quote
