Delphi Posted April 17, 2006 Share Posted April 17, 2006 I am using O2Grapper to create the tvguide.xml (attached) Also attached a .RTF file with screenshots and description of the problem. Any help would be appreciated. Quote Link to comment
Delphi Posted April 20, 2006 Author Share Posted April 20, 2006 RTF file too big so I will describe: Launching myXMLTV from DVBV Pro folder and following the instructions I get the channels DR1, DR2, TV2 Danmark to the left and the correct DVBV channels to the right. This is how I expected. I click on DR1 (left) and select DR1 in the drop down menu. Then I click DR2 ( left) and get the error message:"Listenindex überschreitet das maximum(1)". If I ignore the error message myXMLTV seems to accept, when I click Import. EPG.DAT file is only 22 bytes. I have checked "Do not receive EPG data" and "Persistent EPG Data" in options. DVBViewer was running while trying to update EPG Any help would be appriciated. Has anybody made the EPG work in Denmark? Quote Link to comment
Delphi Posted April 27, 2006 Author Share Posted April 27, 2006 Finally it works After a lot of experimenting I use the following settings in O2Grabber: Channel Naming: Channel Name (Important!) UTF-8 Encoding : Unchecked (Important!) All other Checkboxes: checked (Make Grabber invisible: Unchecked while experimenting) This gave some EPG, but somewhat mixed up. Deleting the EPG.DAT file solved this problem. If you want to start from scratch (to be sure), the following files should be deleted from the DVBViewer folder: Channels.xml (created by myXMLTV) epg.dat (created by DVBViwer on exit) tvguide.xml ( the name I selected in O2Grabber for the output file) I checked the Download Icons checkbox in O2Grabber. This doesn't download the icons, but the tvguide then has an URL pointing to the icon image. I will try to manually download these images later. Quote Link to comment
Delphi Posted April 27, 2006 Author Share Posted April 27, 2006 The icon thing works nice too Copy the PNG files into subfolder .\Images\Logos. Must have the same filename as the channel name in DVBViewer. Restart DVBViewer whenever changes are made in the Logos folder. I am missing channels Canal+ Film 3 and C More Film 2 (They are not present at www.dr.dk where O2grabber does the grab) Found some logos on the net (not nice, but usable). It seems that DVBV has to have a logo for all (favorite) channels in order to show up the right logos in the miniepg when changing channels. I have automated the process via Windows Task Manager using commandline C:\o2grapper\o2grabber.exe -grab (Note the -grab) Quote Link to comment
